  • Member For: 12y 3m 13d
Hi Guys,
Basic question I know but Can anyone please confirm the rotor sizes for a Mk1 G6E Turbo?
DBA catalogue lists both the 298mm and 322mm for fronts and then says check size... Real helpful! :P
I would prefer to order the rotors without having to pull wheels off obviously.
Cheers
https://www.fordxr6turbo.com/forum/topic/92006-rotor-sizes/
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 1m 26d
"check sizes" is probably so they can cover themselves just in case you've changed them from stock. Stock fronts are 322mm or 298mm as the catalogue says, I believe, depending on which G6 model.
https://www.fordxr6turbo.com/forum/topic/92006-rotor-sizes/#findComment-1592298
  • Member For: 12y 11d
the 'turbo' part should mean its the 322mm. DBA must be lazy cause think the 298mm would be for G6E and XR6, XT, etc. I.e. NON TURBO varients
https://www.fordxr6turbo.com/forum/topic/92006-rotor-sizes/#findComment-1592305
  • Site Developer
I found an old post that contained this information:
Brakes off a 2010 G6ET -
Fronts are PBR 2 pot 322mm
Rears are PBR single 303mm
Probably best to measure them to be 100% sure before ordering.
https://www.fordxr6turbo.com/forum/topic/92006-rotor-sizes/#findComment-1592306
