Brake Booster -Repainted Or Replace
Featured Replies
#1
I've lost the paint off the booster, (FG XR50T) twisted master cylinder gasket caused brake fluid to leak over time.
Not sure if I should simply replace with a good 2nd hand unit or try and repainted. Is the booster easy to replace, how long do you think, I would do it myself....
Painting although confident may not look 100% orig and would probably have to remove anyway and wait 24 hrs before refitting.
Thanks
Edited by bad inferno
#2
Just repaint mate. Its only you that sees it and its under the bonnet. Saving $$
  • 3 months later...
#3
Thanks
Mate did you end up fixing this. Was it just a twisted gasket. I have a leak between resivior and booster ford want $700 to fix it. How did you do it
Recently Browsing 0
