May 14, 201511 yr #1 Howdy just after some advice, I have a ba mk11 turbo with all the basic mods, but just in the last few days the idle has been playing up, when ever u pull the car up the idle will run up to around 1400 1500 then drop down to normal idle, its doing it all the time ( engine is hot or cold ) if u pull up under 1000revs it will climb to the 1400-1500 then drop down to normal after that its fine u can sit there reving it and it idles and runs fine but soon as you drive again it will do it, I cant hear no air leaks or anything whats the best place to start checking and cleaning etc cheers ??
May 14, 201511 yr #2 Assuming there are no air leaks...and because it is a BA I would take a guess and say the TPS...
May 14, 201511 yr #3 Author Thanks deff dont think it has any leaks other then what its doing the car is fine runs fine gonna double check tomorrow if I can see anything when u say tps do u mean fkd or out whack or something cheers
May 14, 201511 yr #5 Use throttle body cleaner to look for vacuum leaks... Spray it at all the joins and manifold gasket, if your idle goes up means you got a vacuum leak [emoji106]
