  • Member For: 14y 10m 28d
Posted
Hey guys
The switch has been dicky in my passenger front window for weeks now and hasnt been working, now all of a suddon the driver and the passenger will not work? From the master unit on drivers door I can open both back windows and the back switches work aswell but front wont move at all, I had a look at the fuses but theres no fuse layout on the cover where do I find that? Anyone know if they run on 2 seperate fuses fronts and then backs or if they even have a fuse?
Any help would be great cheers
  • Member For: 14y
Posted
There should be 3 big pink 30 amp fuses. One is for front power windows. The passenger side switch is normally the cause for the short circuit.
  • 2 weeks later...
  • Member For: 13y 1m 14d
Posted
Mine just did the same thing today, but only the passenger side. Pulled out and put fuse back in, now all good.
  • 6 years later...
  • Member For: 11y 5m 12d
Posted
This maybe an old thread, but I just tried this trick on my son's FG window rocker switch and it works a treat.
So worth trying before any of you FG owners go trying to remove the door panels or switch or even taking it to an auto spark.
Time to fix 2 mins
Cost : $0.
Result : F@RKING GOLD.
#Fordxr6turbo.comfor/the/win.
