  • Member For: 12y 2m 16d
Posted
Hi I got an xr6 turbo about a month ago it was going good for the first week but had a slight miss on idle then I changed the plugs and gapped them right,change the coolant and oil aswell I took it up the road for a spin and it boosts fine in first but when I change to second and hit it it's like it's not runing on all cylinders proply like it's running out of fuel so I put a new fuel pump in change the fuel filter put new coils in put another set of plugs in and still has slight miss it's pissing me off I also got it diagnoised and it came up with these codes
P0172 - System to Rich (Bank 1)
P1506 - Idle Air Control (IAC) Overspeed Error
Anyone had this problem
Also if I slowly excelerate on to boost it doesn't do it
But some times it's like it's not boosting need help
  • Member For: 20y 3m 27d
Posted
maybe you should mention whether stock or if not what mods and boost level
Posted
I went to a mechanics shop up the road they used a computer diagnostic thing that plugs into the car any ideas wat could be the problem would it be the boost control solinode
  • New Member
  • Member For: 12y 4m 19d
  • Gender: Female
Posted
Does the car have a highstall in it ?? If so if your running it with less then 1/4 of a tank it will sound like its missing when in natural fact its simply not getting a fuel up. You should be using 98 octane premium or vortex for the turbo model as standard xr6 is different to the XR6 Turbo.
Posted
It's manual and yer man I always run 98 in it I just let some oil out in it it's showing a couple mm under the full line now it's running good but still has a miss
  • 2 weeks later...
