  • Member For: 13y 5m 5d
Hey guys,
My engine has started leaking coolant externally out of the head gasket on the exhaust side. I'm thinking it's a good idea to fix this before it get too much worse.
My question is: After removing the gearbox, fans and radiator etc, can the engine be lifted straight out the top or are there clearance issues requiring a balance bar etc?
Thanks
It looks a little tight up the back, but if you say so :P I was thinking I would do rear main at the same time as it is leaking slowly but it can probably wait.
