patrol_maverick Member 54 Member For: 11y 10m 1d Gender: Male Location: Taree NSW Posted 11/05/14 09:31 AM Share Posted 11/05/14 09:31 AM I've put a BA turbo engine into a Nissan Patrol and it seems somewhat sluggish (struggles to get to 3000rpm). When I take off it feels ok, but when I go to 2nd/ 3rd gear etc the boost struggles to go past 3psi. When the engine was still in a Falcon it drove fine.Also the thermo fans dont work with the PCM. If I ground the relays manually they work fine, and they don't log codes during the KOEO self test (unless I have the relay disconnected) so it appears to be wired fine.Would any of the following codes bare any effect on my situation:P0443 Purge valveP0532 A/C pressure sensorP1465 A/C relayP1565 Speed control command switch (Cruise control??)P1900 CANWith the fan relays disconnected I get P1474/ P1479 codes. Would this affect drivability?Do I need to connect any of these in order for the PCM to work correctly:-Brake switch-Clutch switch-Cruise switches-A/C relay/ pressure switch-Vehicle speed inputI've also fitted a bigger intercooler, a 3 inch exhaust with no cat, and FG exhaust manifold/ dump pipe. Link to comment Share on other sites More sharing options...
patrol_maverick Member 54 Member For: 11y 10m 1d Gender: Male Location: Taree NSW Posted 14/05/14 10:33 AM Author Share Posted 14/05/14 10:33 AM Ok so disregarding the codes in the first post, I have checked the throttle via a data monitor on my scan software and I'm only getting 50% throttle. I have graphs (attached) showing it going to full throttle then dropping back and flatlining at 50% until the pedal is released.I did get one drive with 2 logged codes, P2105 and P2110 (limited power and limp mode), however if it were in limp mode, wouldn't it log a code every time?I have tried 2 different throttles and 2 different accel pedals, but with the same results each time (used parts, condition not known)Fuel pressure remains fairly constant (mechanical guage), and boost seems to stay stable at about 5 psi (via scan tool and mechanical guage).I found a TSB in another thread saying the codes commonly relate to TPS failure, but it only logged the codes once, and the poor throttle have been the same for the past half dozen drives.How much effect would changing the exhaust and intercooler have on the situation? The exhaust has no cat, but the pipe crosses under the engine and runs along the passengers side). I know I should get a tune, but I need to work out what is causing the issue before splashing more money.I've tried to be thorough with the diagnosis (I'm a Nissan dealer technician BTW) but I'm not real familiar with mods/ tunes on Fords. Research tells me Fords don't tolerate mods too well without a tune.Going on this info, can someone tell me if this is more likely a tune related issue caused by the mods, or will I look further into the TPS/ wiring?Shown on the graph you can see where I took off from a standstill, the first spike was accelerating, followed by closed throttle (gear change), then the second acceleration with it dropping back to/ staying at approx 50% open throttle. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m 6d Gender: Male Location: Perth Posted 14/05/14 10:35 AM Share Posted 14/05/14 10:35 AM Can you log torque source? Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 17y 11m 2d Gender: Male Location: @ my laptop Posted 14/05/14 11:43 AM Share Posted 14/05/14 11:43 AM Ralph is on the ball I think Link to comment Share on other sites More sharing options...
patrol_maverick Member 54 Member For: 11y 10m 1d Gender: Male Location: Taree NSW Posted 16/05/14 07:56 AM Author Share Posted 16/05/14 07:56 AM Can you log torque source?Not too sure what you mean by that. Link to comment Share on other sites More sharing options...
JAMESCARGUY20 New Member 1 Member For: 6y 1m 17d Posted 12/03/18 01:04 PM Share Posted 12/03/18 01:04 PM Definately the brake switches and clutch switches have to wired in especially the brake switch had a ba/bf cant remember which one the other day exact same thing fang it in 1st goes well, get it into second and then only 3 psi boost, checked all the fault codes and found brake switch, installed a new one cleared fault codes straight up to 6-7 psi any ways the guy that posted this never came back with the answer or the fix to his vehicle, we would love to hear if you got it fixed??? Link to comment Share on other sites More sharing options...
