Increase Boost!
Featured Replies
#1
Hello all,
A bit of market research here;
What are the current requirements to increase boost?
Has anyone tried uprating their waste-gate actuator?
If so, what are the best on the market (currently).
All feedback is welcome.
Kind regards,
PA
  • Replies 27
  • Views 10.6k
Most Popular Posts
  • Weld the gate shut. No need for waste gate actuator. Exponential boost increase with RPM.
  • Ralph Wiggum
    Ralph Wiggum
    I put a ball bearing in my waste gate hosexand made 42lbs of boost.
  • sexual harrassment panda
    Yeah farken sent from phone via idags4lyf free app
#2
#3
#4
I took off the wastegate line from the turbo
#5
You can just retune your car to make more boost, as the ecu controls the boost to a certain amount. Usually double what the actuator is capable of. Eg a 7psi actuator is good to about 14psi. The garret actuators work very well.
#6
Upgrading the waste gate actuator, what a great idea, wished I thought of it.
I just tied a knot in the hose , but should have used the ball bearing method as I only made 33.3 PSI
#8
  • Author
Are these pneumatic or electric actuators?
Kind regards,
PA
#9
  • Author
By adding a ball bearing to the pressure hose this renders the actuator useless, thus having no boost relief curve. Will just be a sharpe on off with your boost which is not good for the turbo :)
Kind regards,
PA
#10
Great suggestion.
If you do a brake upgrade at the same time. http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=130962922923 , he will combine shipping.
Recently Browsing 0
