December 23, 201312 yr #1 Have a little problem that sh*ts me....cruise control wont turn on....? Yes ive checked clutch and brake pedal switches they seem fine....anything else?? Bem?
December 25, 201312 yr #4 I recently had a problem where I am travelling at say 60km/h(can be at any speed) and then try and press the cruise button to activate cruise. It just kept blinking and would not stay solid. If I press the set button it would not work because cruise was not active, if that makes sense.Turns out that ford took a look at this and said the switch at the brake pedal had failed.A week later that same dsc light came up and cruise would not set.I took it back to ford and was told that the bluetooth obd device plugged into the obd port,was the issue.I have it unplugged for 2 weeks now and I have not had issues since.Do you have anything plugged into the odb port?
December 25, 201312 yr #5 it was happening in my ba Xr8 to. what it was in mine was a stretched hand break cable. so cruise would work then hit a bump or something and it turned straight off. get your hand break tighten can't hurt trying.
January 2, 201412 yr #6 my clutch pedal would not return all the way back up, I had to give it a little pull with my toes and then the cruise would go again... but I changed the switches first... (sucker here, thanks ford)was due to the spring on the clutch pedal return being broken.
