  • Bronze Donating Members
  • Member For: 12y 11d
Serviced the ute today & F ME! the oil that was in that thing was f*ckED! completely shot, non service my ass!
Anyways, nice clean fresh fluid & a filter later the thing drives beaut. One minor issue, I have a TC light illuminated but no DTC's recorded?? Never had an issue with the light the first 2 times the car was driven but with it showing up, I'm a little wary. First time I noticed the light I turned the car on & off and it fixed it. Second time it was started it stayed off as well. Third time it came on & I drove it home. Thing is, I have this cheapy OBD2 recorder unit from ebay which is fantastic, I'd left it in the port & drove it. I'm wondering if that COULD have been the issue. Other thing is if there is some sort error code I'm not seeing ?
To top that off can someone confirm the fill procedure for me? I was under the assumption that you;
top it up till it runs out the hole > start > run through gears > top up till dripping again > once hot put in park & shut off > reapply plug
However, when I did this as soon as the engine was off oil was PISSING out at quite a rate making me think I've over filled so is the procedure the following instead?
top it up till it runs out the hole > start > run through gears > once hot put in park & shut off > reapply plug
Any answers would be awesome, thanks guys
  • ...JD TUNING ADELAIDE...
  • Member For: 17y 1m 11d
  • Member For: 11y 8m 11d
Just 2 things.
First you put the plug back in with the engine running on the 6 speeds. Unlike the old 4 speeds.
Secondly you dont check the level when hot. Its ment to be between 32-45 degrees roughly
