shrunk Member 34 Member For: 14y 5m 8d Gender: Male Location: Christchurch, New Zealand Posted 30/07/13 08:47 PM Posted 30/07/13 08:47 PM Dropped the car off for a service this morning, and wheels were still at near full lock when parked which gave me the opportunity to spot something I hadn't noticed before...95% of the front tyres look perfect, I give them a quick visual inspection fairly often - when washing the car / wheel arches etc... but they were turned close to full lock when I parked the car this morning and I spotted that the inside edge is worn right down past the wire (and quite a bit past).It's not gradual wear, it's about a 45 degree angle of wear on the inner most 3cm of the tyre and deep.Will try get pics (if I don't end up getting the mechanic to get the alignment and new tyres before I pick it up)...But #$%, the rest of the tyres have a sh*teload of tread (at least 6-7mm right across the width of the tyre until you get to that last 3cm).
Bellato Legacy Donating Member 2,713 Member For: 15y 11m 6d Posted 31/07/13 12:53 AM Posted 31/07/13 12:53 AM Neg camber, low psi shot bushesAny or all of these will be your culprit
Bellato Legacy Donating Member 2,713 Member For: 15y 11m 6d Posted 31/07/13 12:54 AM Posted 31/07/13 12:54 AM (edited) Double post and can't delete for some reason Edited 31/07/13 12:55 AM by Bellato
shrunk Member 34 Member For: 14y 5m 8d Gender: Male Location: Christchurch, New Zealand Posted 31/07/13 02:10 AM Author Posted 31/07/13 02:10 AM CheersSorted out a new set of RE002's, getting fitted, balanced and alignment as I type.Hopefully that has it sorted, will keep a closer eye on the very inner from now on...Will get bushes checked out too.
PookeyMaster Legacy Donating Member 1,531 Member For: 15y 9m 6d Gender: Male Location: Parramatta, NSW Posted 31/07/13 02:19 AM Posted 31/07/13 02:19 AM For it to wear down that much you must have either been running them on low PSI for a while or the alignment/camber is absolutely shot.
shrunk Member 34 Member For: 14y 5m 8d Gender: Male Location: Christchurch, New Zealand Posted 31/07/13 04:18 AM Author Posted 31/07/13 04:18 AM I'd say it's the latter - I check pressure / top-up every other month, plus in-laws borrow the regularly and father in law seems to do it at every second refuel
