  • Forged Member
  • Member For: 18y 4m 15d
Rowdy is pointing you in the right direction, check the eye bushes and also check if the steel tube in the centre of the eye bush is rubbing into the rail
  • Will do skids for food
  • Member For: 13y 7m 18d
I had an XG that did that.
Sprayed around the leaves with CRC and that cured it till the next time it rained and it got washed away.
Once the rain dried off the springs it would creak again. f*cken POS.
  • Brisbanes Resident Detailer
  • Member For: 16y 5m 2d
My ute used to creak in the rear at slow speeds. Turned out to be the tailgate moving slightly.
  • Member For: 13y 6m 21d
Problem solved!
U-bolts that wrap around the diff, I put loctite on them
And tightened them up completely
Amazing how many turns I got out of them!
Lesson learned.
Inspect your pride after another one has done work on it!
Then again this could be wear and tear.
Thanks all for the support and suggestions !
Glen
  • Member For: 17y 3m 2d
Mine started doing this a couple of days ago. Took it into Pitlane today, tightened U bolts and its fixed.
