Hey guys.
First I wanna thank the guys that helped me out with my E85 questions.
Im making 411rwkw on 20psi running dedicated e85 through 2000cc injectors(they're too big, I'm working on going to 1000s).
But I seem to be popping the welds on my surge tank. This is the third time its happened. The tank has been made by Dr Bolt here in Adelaide, and I'm confident in his workmanship. Im lead to believe that it happens only when I fill my main tank to the brim.
I have 2x 044s feeding the fuel rail, a 265L/h feeding the surge tank and brand new 3/8 lines the whole way through the car. I can guarantee there is no restriction in the fuel system anywhere.
Ive been told that falcons will only support round surge tanks, but I think that's a load of crap...
Any ideas, suggestions or thoughts?
https://www.fordxr6turbo.com/forum/topic/85000-popping-my-surge-tank/
  • Member For: 18y 7m 13d
I've heard this happen to a car 4 times, it was either the inlet or outlets were too small and built to much pressure inside the surge
  • Moar Powar Babeh
  • Member For: 19y 7m 18d
if you're popping tanks you either have
A: Poor workmanship in either designing or fabricating the tank
B: Pressure build up in the tank
how big is the largest flat panel in the tank? 200mm x 150mm? @ 58psi in the tank you could be seeing around 2600lb's of force on panel (sizes are pie in the sky estimate to illustrate my point)
If you have a look at any of the off the shelf "square" tanks they are all machined from hefty billets of ally not fabbed from flat plate, there's a reason for this and also a reason why pressure vessels are round
Is your rail return plumbed into the surge or the main tank?
Rail returns to the surge tank.
Dr bolt makes plenty of surge tanks, fuel tanks, drop tanks etc. He is no stranger to the game.
I dont have the money to be buying another surge tank, and I need mine back before Friday.
He has the tank at the moment repairing it, again. So I can't measure it.
The last time I got it back I did a pressure test and it was at 28psi at the return hose on the sender unit.
  • Moar Powar Babeh
At 20psi boost your tank will be seeing 48+psi if your seeing 28 @ idle. Plumb the return line straight into the main tank and try again
  • Moar Powar Babeh
not sure what you mean there mate, the check valves are designed to stop pressure bleeding down from the pumps when they are shut off.
The fuel pressure reg is boost reference @ a 1 to 1 ratio, base fuel pressure is 58psi so every psi of boost you add pressure in the rail increases be the same amout. This increases the load on the 044's and the intank feeding them, which will drive pressure in the surge tank up.
