January 12, 200422 yr #1 Well question says it all, went to flick the T around and ah didnt happen, either I have a very loose handbreake needing adjusting or ABS, is that possible? I'd have thought the handbrake would be direct cable connection and over ride ABS.
January 13, 200422 yr #4 Dont think ABS is connected in any way to the hand brake.However, I can confirm through experience that the ABS does work whilst going backwards.....................
January 13, 200422 yr #5 Well question says it all, went to flick the T around and ah didnt happen, either I have a very loose handbreake needing adjusting or ABS, is that possible? I'd have thought the handbrake would be direct cable connection and over ride ABS.The handbrake is a direct mechanical link, whereas the ABS is controlled electronically so I doubt the two are connected. I've been told the handbrake in the fords can't withstand that type of punishment, have you ever noticed the handbrake in the VB challenge cars? Definately not stock. But hey it's your car treat her as you see fit.
January 13, 200422 yr #6 I too have heard that the Handbrake can remove the brake shoes from their mountings if used for stopping or turning. Definately not a good idea.
