rokkie Member 87 Member For: 12y 9m 1d Gender: Male Location: Adelaide, SA Posted 16/04/13 01:04 PM Share Posted 16/04/13 01:04 PM Hi all I have non modded ba xrt and getting very high fuel consumption.. about 19.3L and getting about 300km to a tank (with grandpa driving) I have checked the short fuel trim (shft2) and it is 33% which I know is very high! Vehicle doesn't run or idle rough. Swapped upstream o2 sensor, new fuel filter, plugs and different cam angle sensor on the exhaust (had codes for timing over advanced) inlet is also tight. Does anybody have any ideas why the fuel trim is high or any suggestions? Thanks Sent from my GT-P5110 using Tapatalk 2 Link to comment https://www.fordxr6turbo.com/forum/topic/84645-high-fuel-consumption/ Share on other sites More sharing options...
spinr33 Donating Members 964 Member For: 13y 10m 4d Posted 16/04/13 08:21 PM Share Posted 16/04/13 08:21 PM Have you tried disconnecting the battery to reset the ecu ? Link to comment https://www.fordxr6turbo.com/forum/topic/84645-high-fuel-consumption/#findComment-1381215 Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 7m 26d Gender: Male Location: Far north queensland Posted 16/04/13 08:33 PM Share Posted 16/04/13 08:33 PM blocked cat? Link to comment https://www.fordxr6turbo.com/forum/topic/84645-high-fuel-consumption/#findComment-1381216 Share on other sites More sharing options...
rokkie Member 87 Member For: 12y 9m 1d Gender: Male Location: Adelaide, SA Posted 16/04/13 10:43 PM Author Share Posted 16/04/13 10:43 PM Have rest the ecu multiple times and within a few minutes back up high. If it was a blocked cat should its performance be lacking? It boosts quite hard though Sent from my GT-I9300 using Tapatalk 2 Link to comment https://www.fordxr6turbo.com/forum/topic/84645-high-fuel-consumption/#findComment-1381226 Share on other sites More sharing options...
rokkie Member 87 Member For: 12y 9m 1d Gender: Male Location: Adelaide, SA Posted 26/04/13 10:30 AM Author Share Posted 26/04/13 10:30 AM I think I found the problem. Always wondered why boost would be there and not at other times. It turns out the exhaust camshaft wiring was resting on the exhaust manifold and melted both wiring insulations and grounding out at times. Gone to be a fun job repairing it. Hopefully economy gets better too Sent from my GT-I9300 using Tapatalk 2 Link to comment https://www.fordxr6turbo.com/forum/topic/84645-high-fuel-consumption/#findComment-1384123 Share on other sites More sharing options...
jas98 Member 1,049 Member For: 12y 10m 29d Gender: Male Location: Maryborough Qld Posted 29/05/13 01:51 PM Share Posted 29/05/13 01:51 PM how did you go with this? Link to comment https://www.fordxr6turbo.com/forum/topic/84645-high-fuel-consumption/#findComment-1393950 Share on other sites More sharing options...
rokkie Member 87 Member For: 12y 9m 1d Gender: Male Location: Adelaide, SA Posted 08/12/13 12:21 PM Author Share Posted 08/12/13 12:21 PM it's been awhile since I did the repair I was averaging 19.6L/100 now its down to 16L/100 I know its not great but better as its only 3 kms to work every morning Link to comment https://www.fordxr6turbo.com/forum/topic/84645-high-fuel-consumption/#findComment-1444656 Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 11y 11m 19d Gender: Male Posted 09/12/13 09:03 AM Share Posted 09/12/13 09:03 AM Haven't melted through a vac hose as well have you? Link to comment https://www.fordxr6turbo.com/forum/topic/84645-high-fuel-consumption/#findComment-1444831 Share on other sites More sharing options...
rokkie Member 87 Member For: 12y 9m 1d Gender: Male Location: Adelaide, SA Posted 09/12/13 09:26 AM Author Share Posted 09/12/13 09:26 AM Cant say I know of any vacuum hoses that run near anything hot. I did the inlet manifold gasket around the time I was looking for the fault. Sent from my GT-I9505 using Tapatalk Link to comment https://www.fordxr6turbo.com/forum/topic/84645-high-fuel-consumption/#findComment-1444837 Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 11y 11m 19d Gender: Male Posted 10/12/13 09:35 AM Share Posted 10/12/13 09:35 AM It could just be a hose with a small hole in it or even a hose blown off a barb Link to comment https://www.fordxr6turbo.com/forum/topic/84645-high-fuel-consumption/#findComment-1445044 Share on other sites More sharing options...
