  • Member For: 15y 8m 1d
A quick search on eBay shows that 1/2-20 taps are available. So why is dags refering to unobtanium?
Am I seeking to fulfil an impossible task or what?
I think dags thought you were going to try and make a 1/2 - 20 knob fit on a 10 -1.5 shifter
The root of a 10 x 1.5 thread should be 8.55mm, drill this out to 11.5mm and then you can tap your new thread. As long as there is enough meat you will be fine.
quick question : Why?
  • Member For: 13y 9m 20d
Cheers for that shp. There's plenty of meat inside the knob.
f*ck that sounds dodgy.
All will be revealed when the car is back together :)
  • Bored Member
  • Administrator
  • Member For: 22y 7m 13d
I thought he was going to try thread cutting the shifter stalk..hence using a die not a tap....
See username... :locomotive:
Lol. If you're referring to my username, I used to be a Expensive Daewoo boy, hence converted. But you're on the right track ;)
