dswiders Member 398 Member For: 21y 6m 11d Gender: Male Location: Boronia, Vic Posted 09/01/04 05:38 AM Share Posted 09/01/04 05:38 AM Can someone help me regarding changing the standard Ford brakes to DBA's ?I've phoned Repco Parts for both the Longlife Gold & the Slotted.I'm not sure if I should go:-1. Drilled on the Front with Slotted on Rear2. Drilled all round3. Slotted all roundWhat is better to do / advantages disadvantages ?The other thing is replacing the standard pads with Ferodo, howeverRepco say that they have replacements only for the front and NOT the rears What do I do with the rears, do I leave it as standard Ford ones ?All help to clarify this would be most appreciated.Daniel Link to comment https://www.fordxr6turbo.com/forum/topic/8433-dba-brakes-pads/ Share on other sites More sharing options...
hypnodoc It's All In Your Mind Gold Donating Members 2,198 Member For: 21y 7m 7d Gender: Male Location: Melbourne Posted 09/01/04 06:46 AM Share Posted 09/01/04 06:46 AM Can someone help me regarding changing the standard Ford brakes to DBA's ?I've phoned Repco Parts for both the Longlife Gold & the Slotted.I'm not sure if I should go:-1. Drilled on the Front with Slotted on Rear2. Drilled all round3. Slotted all roundWhat is better to do / advantages disadvantages ?The other thing is replacing the standard pads with Ferodo, howeverRepco say that they have replacements only for the front and NOT the rears :banghead: What do I do with the rears, do I leave it as standard Ford ones ?All help to clarify this would be most appreciated.Daniel Mate you forget about the excesses of REPCO and you ring Hoppers Stoppers in Hoppers crossing Vic (1223 for their phone number) a rather nice gent will answer the phone and he will supply you with front and rear DBA drilled/slotteds for $620 delivered, you then find yourself a set of FERODO performance pads and your T will stop quickly in a straight line every time. No good hving diamonds on the front and coloured glass on the rear, go the extra cost and you'll be happy. I am, and Cro is and he can burn out Bendex's in no time. Link to comment https://www.fordxr6turbo.com/forum/topic/8433-dba-brakes-pads/#findComment-80822 Share on other sites More sharing options...
Cro Flower Power Lifetime Members 6,114 Member For: 22y 7m 26d Gender: Male Location: Sydney Posted 09/01/04 07:39 AM Share Posted 09/01/04 07:39 AM I'd be going for DBA 4000 slotted.Not long life.Both are good, but 4000 is higher specced. Link to comment https://www.fordxr6turbo.com/forum/topic/8433-dba-brakes-pads/#findComment-80848 Share on other sites More sharing options...
Trumpy What's happening? Lifetime Members 1,605 Member For: 22y 6m 2d Gender: Male Location: Steel City, NSW Posted 09/01/04 11:02 AM Share Posted 09/01/04 11:02 AM Depends what you are after Daniel.If this is purely a road setup, then the Longlife should be OK. If you want to do some track work, go for the 4000 series.I did a fair bit of reading before changing mine, and in most applications the cross drilling seems to be for aesthetics only. Not worth the extra dollars. For that reason I went for Longlife Slotted.I only replaced the fronts, leaving the rears as standard ford disks.I replaced all the pads (front and rear) and would recommend you do the same. Replacing the rear disks is not as important, and my opinion was that I would put the rear slotteds on after I wore out the standards (cant take that long with Ultimates).I have done 2 track days on my Longlife slotted/Bendix Ultimate setup and it is really good. I am very happy with the way the brakes last, and it stops very well with good pedal feel. Cro has not had the best experience with the Ultimates, but is going well with the 4000 fronts / Ferodo pads. I guess see what is easily available to you. Link to comment https://www.fordxr6turbo.com/forum/topic/8433-dba-brakes-pads/#findComment-80900 Share on other sites More sharing options...
Dagabond Bored Member Administrator 35,722 Member For: 22y 6m 22d Gender: Male Location: Dé·jà vu Posted 09/01/04 01:42 PM Share Posted 09/01/04 01:42 PM As they said Daniel and follow hypnodoc's advise you'll get a much better price from Hoppers Stoppers: http://www.hoppers.com.au/Cross drilled also have a tendancy to crack. Link to comment https://www.fordxr6turbo.com/forum/topic/8433-dba-brakes-pads/#findComment-80932 Share on other sites More sharing options...
Merlin Member 57 Member For: 21y 11m 4d Gender: Male Location: Sydney Posted 09/01/04 10:50 PM Share Posted 09/01/04 10:50 PM ive decided to go DBA longlife gold on the front - as I like the crossdrilled look. problem is everywhere I ring gives me a different price. I was expecting $300 for the pair but cheapest so far is $440 at supercheap. im in NSW. Can anyone tell me what they paid? Link to comment https://www.fordxr6turbo.com/forum/topic/8433-dba-brakes-pads/#findComment-80970 Share on other sites More sharing options...
hypnodoc It's All In Your Mind Gold Donating Members 2,198 Member For: 21y 7m 7d Gender: Male Location: Melbourne Posted 10/01/04 12:17 AM Share Posted 10/01/04 12:17 AM ive decided to go DBA longlife gold on the front - as I like the crossdrilled look. problem is everywhere I ring gives me a different price. I was expecting $300 for the pair but cheapest so far is $440 at supercheap. im in NSW. Can anyone tell me what they paid? Hoppers StoppersDBA drilled/slotted Golds $330 pair delivered. Link to comment https://www.fordxr6turbo.com/forum/topic/8433-dba-brakes-pads/#findComment-80993 Share on other sites More sharing options...
hypnodoc It's All In Your Mind Gold Donating Members 2,198 Member For: 21y 7m 7d Gender: Male Location: Melbourne Posted 10/01/04 12:21 AM Share Posted 10/01/04 12:21 AM Cross drilled also have a tendancy to crack. I have been drilled front and rear. Ahhhhhhhhhh does that mean I'm gonna crack. Link to comment https://www.fordxr6turbo.com/forum/topic/8433-dba-brakes-pads/#findComment-80995 Share on other sites More sharing options...
geea Site protagonist Lifetime Members 4,320 Member For: 22y 25d Gender: Male Location: At the lights, waiting for you. Posted 10/01/04 10:14 AM Share Posted 10/01/04 10:14 AM Cross drilled also have a tendancy to crack.I have been drilled front and rear. Ahhhhhhhhhh does that mean I'm gonna crack. I think being drilled front and rear may get you a ride on a float at the Sydney Mardi gras. I'll be running along now. Geea Link to comment https://www.fordxr6turbo.com/forum/topic/8433-dba-brakes-pads/#findComment-81070 Share on other sites More sharing options...
dattoman Member 67 Member For: 21y 11m 23d Location: Perth Western Australia Posted 10/01/04 02:45 PM Share Posted 10/01/04 02:45 PM If your willing to wait alittle while DBA has something new in the works for you crossdrilled/slotted lovers. Link to comment https://www.fordxr6turbo.com/forum/topic/8433-dba-brakes-pads/#findComment-81137 Share on other sites More sharing options...
