Passenger Side Battery Relocation - A Few Q's
Featured Replies
#1
Hi,
I want to relocate the battery to the passenger side.
I was intending on just cutting the battery terminals off, crimp, solder and heatshrink on some cable extensions and running them across to the passenger side and then fitting terminals to the end of the new cables.
My question is.... what is the best cable type for this purpose as I know there are a number of different grades of cable depending on the distance traveled etc.
#2
  • Author
anybody?
#3
400 amp jumper leads
#4
I would just undo the battery cable from the battery to the fuse box. Then run your positive cable from the battery to the starter motor, leave the cable on that goes from the starter motor to the fuse box. And with the negative just find a sutiable earth, it would be alot neater then running cables across the bay and less cable. I would use 35mm cable.
#5
  • Author
Brilliant thanks.
#6
Fuse boxed supplied from Starter is not ideal.
I prefer to run a positive lead from the battery to the start, Earth lead to PS engine mount to engine block bolt and run another smaller Positive feed from the battery to the fuse box across the front of the car in the channel above the Rad.
  • 2 weeks later...
#7
what would you use for a battery tray and how would you mount it ?
#8
Lol
#9
Lol
another constructive comment...........
#10
Try doing a search for battery relocation, kits are available or make it yourself...
Recently Browsing 0
