Frankg Member 20 Member For: 21y 11m 24d Location: Adelaide Posted 02/01/04 04:00 AM Share Posted 02/01/04 04:00 AM Just wanted to know if anyone else has had the problem of handbrake constantly needing adjustment.!!!Just before my 15k service the back brakes were scraping pretty badly due to handbrake... I always use my handbrake when parking and never thought it should be a problem ?? (Right)So after 15k service it was ok but now another 2000ks and back brakes are scraping again!!! ahhhh I hope this is going to continue..??Any Ideas??? Link to comment https://www.fordxr6turbo.com/forum/topic/8273-handbrake-problems/ Share on other sites More sharing options...
NT TURBO Member 1,128 Member For: 22y 4m Gender: Male Location: Darwin NT Posted 02/01/04 04:11 AM Share Posted 02/01/04 04:11 AM mine scraped too, they removed the rear disc and sanded the high (polished from scraping) spots off the handbrake lining, been fine ever since, probably 3000k ago. Link to comment https://www.fordxr6turbo.com/forum/topic/8273-handbrake-problems/#findComment-78144 Share on other sites More sharing options...
ducatijb Lifetime Members 3,448 Member For: 22y 3m 12d Gender: Male Location: sydney Posted 02/01/04 04:19 AM Share Posted 02/01/04 04:19 AM It's a bloody embarrassment,mine was given the Ford fix 3000k's ago and it's back louder than ever :banghead: :banghead: Link to comment https://www.fordxr6turbo.com/forum/topic/8273-handbrake-problems/#findComment-78146 Share on other sites More sharing options...
ktford FORD FORD FORD Donating Members 9,390 Member For: 22y 3m 28d Gender: Male Location: Victoria Point In Brissy's eastern side Posted 02/01/04 05:04 AM Share Posted 02/01/04 05:04 AM Mine went back twice before they got it right, touch wood or head.Scotty Link to comment https://www.fordxr6turbo.com/forum/topic/8273-handbrake-problems/#findComment-78179 Share on other sites More sharing options...
AMoffat Member 744 Member For: 22y 7m 8d Posted 02/01/04 05:10 AM Share Posted 02/01/04 05:10 AM I have wondered about this - mine don't scrape but were adjusted at 15,000Klms and need adjustment again (20,000Klms).The embarressing thing is you need to cover hold the car on the foot brake as the handbrake allows it to move in either direction when in gear. Link to comment https://www.fordxr6turbo.com/forum/topic/8273-handbrake-problems/#findComment-78181 Share on other sites More sharing options...
Cro Flower Power Lifetime Members 6,114 Member For: 22y 9m 5d Gender: Male Location: Sydney Posted 02/01/04 06:08 AM Share Posted 02/01/04 06:08 AM Happens to me too. When I get the dealer to fix it comes back after 100kms :( Link to comment https://www.fordxr6turbo.com/forum/topic/8273-handbrake-problems/#findComment-78193 Share on other sites More sharing options...
FORDTECH Member 383 Member For: 22y 1m 15d Location: On the edge Posted 02/01/04 10:26 PM Share Posted 02/01/04 10:26 PM This problem has come to my attention at the dealership where I work quite often so I investigated it a bit further and found that when the vehicles were being serviced and the park brake needed adjusting the tech's were adjusting them incorectly.All they were doing was removing the rear wheels and screwing the adjusters out until the hub starts to bind and then reassembling them.So what I did was referenced the correct adjusting procedure from the workshop manual and found that there is a rather complex procedure that you have to go through to adjust them properly.Then we started adjusting them as per the correct procedure and havent had any trouble since.Also guys,if anybody knows how to seperate pages from a PDF(Acrobat Reader)document please let me know and I can post the procedure for everyone. Link to comment https://www.fordxr6turbo.com/forum/topic/8273-handbrake-problems/#findComment-78328 Share on other sites More sharing options...
Cobra potty trained Lifetime Members 1,938 Member For: 22y 2m 20d Gender: Male Posted 03/01/04 12:05 AM Share Posted 03/01/04 12:05 AM Also guys,if anybody knows how to seperate pages from a PDF(Acrobat Reader)document please let me know and I can post the procedure for everyone. not as easy as it sounds, PDFs are meant to be a secure/uneditable/total documentsI try and print pages to a file, which sometimes works and sometimes notFordTech - maybe email me the file and I'll try extract the relevant pagescheersRob (blkxrt@hotmail.com) Link to comment https://www.fordxr6turbo.com/forum/topic/8273-handbrake-problems/#findComment-78363 Share on other sites More sharing options...
Guest Scootre Guests Posted 03/01/04 02:50 AM Share Posted 03/01/04 02:50 AM Also guys,if anybody knows how to seperate pages from a PDF(Acrobat Reader)document please let me know and I can post the procedure for everyone.not as easy as it sounds, PDFs are meant to be a secure/uneditable/total documentsI try and print pages to a file, which sometimes works and sometimes notFordTech - maybe email me the file and I'll try extract the relevant pagescheersRob (blkxrt@hotmail.com) Errrmmm... actually PDFs are designed to take an entire document - pics, fonts & text flow and retain the way the doc was designed across any platform. It is especially handy because it encapsulates fonts and therefore gets around the issues of having to distribute fonts along with a document which constitutes a breach of copyright. It is true that PDFs can be made secure - password protected to stop people printing, extracting, saving and so on BUT you have to specifically do that to the original doc. They are not 'locked' as a rule. So... to extract the pages, you need a pdf authoring package like Adobe Acrobat - which is the commerical equivalent to the freely available Acrobat Reader.Alternatively, there are freely available PDF progs out there for all platforms (try www.planetpdf.com) or, if you're in to Linux, try some of the packages that came with your distro.Assuming the creator of the PDF didn't deliberately lock your PDF, then using Adobe Acrobat open the doc and use the extract pages command from the Document menu. Alternatively, save a copy of the doc and then use the 'delete pages' command from the Document menu (the latter is quicker if you have non-contiguous pages).If you have no luck, PM me and I'll give you an email address to send it to and I'll fix it for you. Link to comment https://www.fordxr6turbo.com/forum/topic/8273-handbrake-problems/#findComment-78400 Share on other sites More sharing options...
Cobra potty trained Lifetime Members 1,938 Member For: 22y 2m 20d Gender: Male Posted 03/01/04 03:36 AM Share Posted 03/01/04 03:36 AM all the Ford manuals I've got are protected so they can not be edited or parts taken out of contextwe'll get the info out there somehow Link to comment https://www.fordxr6turbo.com/forum/topic/8273-handbrake-problems/#findComment-78408 Share on other sites More sharing options...
