Brendan Donating Members 19 Member For: 18y 1m 24d Gender: Male Location: Central QLD Posted 31/10/12 11:59 PM Share Posted 31/10/12 11:59 PM So I noticed an exhaust sound coming from somewhere around the footwell, initially thought it was the exhaust but after looking at it last night noticed there was a gap between the turbo and manifold and 3 of the bolts where missing and the 4th was sitting there very loosley.Basically my question is, is there any way to get these new 'double ended bolts' (not sure what they are exactly called) I got from ford in without havin to remove the entire turbo? Any help would be greatly appreciated. Link to comment https://www.fordxr6turbo.com/forum/topic/82667-turbo-bolts-missing-manifold-side/ Share on other sites More sharing options...
_Velocity_ Bronze Donating Members 2,768 Member For: 14y 1m 19d Gender: Male Location: Victoria Posted 01/11/12 01:51 AM Share Posted 01/11/12 01:51 AM Nope. Bottoms ones won't fit through the tiny gap to slide in. Link to comment https://www.fordxr6turbo.com/forum/topic/82667-turbo-bolts-missing-manifold-side/#findComment-1318596 Share on other sites More sharing options...
GTEXXED Banned Banned 910 Member For: 12y 10m 24d Gender: Male Posted 01/11/12 03:50 AM Share Posted 01/11/12 03:50 AM It is possible to fit these with the turbo on,done it a few times myself.Unbolt the actuator so its got some play in it and some extensions and 14mm 3/8 drive can send it home....it's hard to explain 100% and as my car is at paint shop I can't take a pic to point to the area.Anyway,it can be done so just have a look at the ways possible slowly until you see the one where the tools I described looks like will do the job.You feed one extension in with the 14mm socket onto the nut(have nut fully screwed onto thread first)through under the comp housing and locate the threaded end into the manifold,add to this another extension to get ratchet in a good place for easy spinning.remove all turbo piping from crossover and do the job on a cold motor.In all honesty I would do away with the ford nuts and get some Nordlock bolts/nuts in same diam,problem solvered for ever. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/82667-turbo-bolts-missing-manifold-side/#findComment-1318673 Share on other sites More sharing options...
Brendan Donating Members 19 Member For: 18y 1m 24d Gender: Male Location: Central QLD Posted 01/11/12 05:34 AM Author Share Posted 01/11/12 05:34 AM Thanks heaps for your help! I know what your getting at from what I was looking at last night, see how I go. If not ill just pull the whole thing out lol. Thanks again for your help. Link to comment https://www.fordxr6turbo.com/forum/topic/82667-turbo-bolts-missing-manifold-side/#findComment-1318756 Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 5m 28d Gender: Male Posted 01/11/12 08:19 AM Share Posted 01/11/12 08:19 AM I'm going to have another look at this. I have some stage 8 nuts, inconel studs and some nordlock washers for the head to manifold. Link to comment https://www.fordxr6turbo.com/forum/topic/82667-turbo-bolts-missing-manifold-side/#findComment-1318849 Share on other sites More sharing options...
oplock27 Member 36 Member For: 12y 6m 25d Gender: Male Posted 07/01/13 12:31 PM Share Posted 07/01/13 12:31 PM Experiencing this problem at the moment turbo is hanging on (loosely) by 2 studs only. Any recommendations for replacement to avoid this happening again? Also what is thread pitch? Might just pull one out and take to shop to match anyway. Link to comment https://www.fordxr6turbo.com/forum/topic/82667-turbo-bolts-missing-manifold-side/#findComment-1346120 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,543 Member For: 17y 2m 3d Gender: Male Location: Melbourne Posted 07/01/13 12:44 PM Share Posted 07/01/13 12:44 PM see this thread for all the relevant information http://www.fordxr6turbo.com/forum/topic/77956-why-does-my-turbo-keep-falling-off/?hl=%2Bstage8#entry1168990 Link to comment https://www.fordxr6turbo.com/forum/topic/82667-turbo-bolts-missing-manifold-side/#findComment-1346129 Share on other sites More sharing options...
