turbowelshy89 Member 147 Member For: 16y 2m 5d Posted 04/10/12 10:23 PM Posted 04/10/12 10:23 PM Oh I thougt they were a arp stud. My bad. Is it boost that lifts heads or power?
rbjet Skid Machine Legacy Donating Member 1,640 Member For: 15y 4m 7d Gender: Male Posted 04/10/12 10:32 PM Posted 04/10/12 10:32 PM If the op is only planning on making 400rwkw and not running 20psi+ does he really need 12mm head studs?I'm sure the off the shelf ARP standard size would be fine.
senna_T Forged Member Legacy Donating Member 15,818 Member For: 19y 7m 24d Gender: Male Location: SW Sydney Posted 04/10/12 10:36 PM Posted 04/10/12 10:36 PM I'd get an Atomic Re-build kit, genuine gasket set and an Atomic oil pump. This is all providing you haven't punched a crank inspection hole in your block... In that case, buy a short motor... 1
bionicxr6t05 Legacy Donating Member 2,216 Member For: 15y 2m 4d Gender: Male Posted 05/10/12 12:22 AM Posted 05/10/12 12:22 AM 12mm is the standard size....
atomicyellowute Member 92 Member For: 14y 5m 6d Posted 05/10/12 03:21 AM Author Posted 05/10/12 03:21 AM Is there any difference between the ba block and bf? Apart from skinnier rods of coarse
senna_T Forged Member Legacy Donating Member 15,818 Member For: 19y 7m 24d Gender: Male Location: SW Sydney Posted 05/10/12 03:22 AM Posted 05/10/12 03:22 AM Nah, the B-series blocks are the same. The internals went to the stronger version 06/2006
Ralph Wiggum Moar Powar Babeh Legacy Donating Member 19,334 Member For: 21y 8d Gender: Male Location: Perth Posted 05/10/12 03:28 AM Posted 05/10/12 03:28 AM bit fuzzy here but was it bf block or sump that had the ZF cooler mounts added mid run?
stee3 Member 194 Member For: 15y 3m 6d Posted 05/10/12 03:35 AM Posted 05/10/12 03:35 AM Blocks are the same the BF sumps have the ZF cooler mounts. 1
Ralph Wiggum Moar Powar Babeh Legacy Donating Member 19,334 Member For: 21y 8d Gender: Male Location: Perth Posted 05/10/12 03:35 AM Posted 05/10/12 03:35 AM ^ WHS
straughsberry Legacy Donating Member 1,846 Member For: 19y 1m 13d Gender: Male Location: Broady, Melbourne Posted 05/10/12 03:43 AM Posted 05/10/12 03:43 AM I still have a couple of sets of Mahle Powerpak pistons and Argo rods from when I did a bulk buy a couple of years ago. I just want to get rid of them so if anyone is interested, send me a PM for price.If your'er after 14mm studs, you can use 460BB studs. 1
