  • Member For: 14y 1m 14d
Posted
Yeah looked at that. More fact which hose is the relase and which one lets the air into the bov if that makes senes as this one your relase hose.isnt used
  • Legacy Donating Member
  • Member For: 15y 11m 20d
Posted
Maybe put up a pic of your BOV to try and explain it better? If it vents into atmosphere shouldn't you just need to put it into the cooler pipe where the old one was and run the vacuum line? Didn't think there was anymore hoses unless you plumb it back into the intake
  • Member For: 14y 3m 7d
Posted
The hose on the pipe that goes into the bottom of the stock blow off valve is the one that goes into the bottom of your aftermarket blow off valve, the other hose just will get blocked off...
Help any?
