September 13, 201214 yr #1 Hey guys, I'm in the middle of purchasing a 09 XR6T from a dealer with 97k on the clock. I noticed on the test drive that there is a distinct vacuum/air/ boost noise coming from behind the dash and gets stronger the harder I push. It doesn't seem to impair performance or idle, it's just noisy, not something the stereo could or should drown out. I've driven probably 3 FG turbos so far and none of them had this issue. So the dealer took it down to ford I get looked at and they couldn't find anything (nothing loose or cracked in the eng bay) and said its normal. The dealer I'm buying the car from actually drives a G6ET, and he knows it isn't normal, so he is looking into it himself. Any pearls of wisdom as to what may be causing this? I was wondering if the guy who owned it previously had extra gauges mounted and removed before sale and there is an open line begin the dash.... It's that loud...Thanks guys!
September 13, 201214 yr #2 maybe the silencer has been removed and replaced?K&N panel filter might be in the air box instead of stock filter?
September 13, 201214 yr #3 Author I could understand that adding to the induction noise from the engine bay, but this really sounds like the air rush you would get from the nozzle of a vacuum cleaner in the cabin near the drivers side A pillar. I'm meant I be picking it up tonight, so I'll check the air box. Thanks!
September 14, 201214 yr #4 I had air noise in my last FG, always sounded like the drivers side window wasn't quite closed properly or the door not sealing (noise came from around where the drivers side mirror is). only really noticed it at 80+km/hr but annoyed the hell out of me. the car had only done 50k kms... not sure if this is what you're experiencing?
September 14, 201214 yr #6 Author I can make the noise when the car is at a standstill, doesn't change in pitch with revs, only increses air velocity/ volume...
September 14, 201214 yr #8 Author Stranger things have happened! Looking at worst case scenarios, whatever it is shouldnt be causing damage from what I can gather, just annoying; mabe I just settle on the car with a cash adjustment and slowly nut it out myself...I just want to be fairly certain that somehow its not causing something stupid like a lean out condition... Noises- I can live with for a price, engine damage I can't.
September 14, 201214 yr #9 Author Ok, just spoke to the dealer and he said the noise was the brake booster where it goes through the firewall. He sealed it and the noise is apparently much less, but not gone, anyone else had a similar issue and short of shelling out for another booster, is there a fix?
September 14, 201214 yr #10 Author After a bit of looking around online, I see that fg LPG models had a recall due to vacuum leaks associated with the brake booster and it's check valve, but nothing really to do with the petrol falcons. I wonder if it's only a batch of bad ones that only went on the LPG ones, or it shows up more on those models. Sounds almost too similar to be coincidence.
