ChrisJager123 Member 43 Member For: 17y 7m 28d Posted 27/08/12 02:38 PM Posted 27/08/12 02:38 PM Hi guys have anyone one of you ever had throttle faults or well rather odd things happen my car seem to have had a throttle fault while driving and didnt turn out so good I know of a few guys that have had a sticking throttle of sorts and pretty sure nizpro have seen it before anyone know what brings on a throttle being stuck?? thanks alot guys..
Mr_4.0 Member 1,096 Member For: 15y 8m 10d Posted 28/08/12 01:58 AM Posted 28/08/12 01:58 AM That was really hard to read in one sentence. Try tps on throttle body, try new accelerator pedal and clean throttle body with some carby cleaner.
XR6menace BANNED Banned 1,462 Member For: 19y 5m 1d Gender: Not Telling Location: banned Posted 28/08/12 05:37 AM Posted 28/08/12 05:37 AM Second all of the above...*clean TB first*scan for fault codes and / or change the TPS sensor*check floor mat isnt interfering with pedals....
ChrisJager123 Member 43 Member For: 17y 7m 28d Posted 30/08/12 01:57 AM Author Posted 30/08/12 01:57 AM Sorry guys just wanted to get it out fast.. Just one of those days so have you guys heard of this before??
straughsberry Legacy Donating Member 1,846 Member For: 19y 1m 11d Gender: Male Location: Broady, Melbourne Posted 30/08/12 04:52 AM Posted 30/08/12 04:52 AM I had a throttle problem. Logged faults showed throttle control system limiting RPM (which felt like a sticky throttle) then engine shutdown. Cleaning the electrical connextions to the TPS fixed the issue for me.
Kosij Legacy Donating Member 2,045 Member For: 15y 1m 19d Gender: Male Posted 30/08/12 05:14 AM Posted 30/08/12 05:14 AM If you have the older shaped TPS more then likely it will be playing up. I replaced mine with the newer one and never had a throttle problem.Mine used to drop revs and shake really bad and chuck out max rpm limit codes.
ChrisJager123 Member 43 Member For: 17y 7m 28d Posted 01/09/12 01:29 PM Author Posted 01/09/12 01:29 PM Thanks for the replys guys. I was driving up gears and thottle spiked up hit mid boost on a cold nite.... and not alot of people believe stuck throttles happen!. So it seems being 27 years old and owning a F6 makes you a rev head and that just makes every one of us car lovers look bad.. And that my friend is not on.. thanks alot guys with your feed back.
