ian69 Bronze Donating Members 31 Member For: 11y 9m 16d Posted 19/08/12 05:20 AM Share Posted 19/08/12 05:20 AM hello im new on here and have read a lot off posts .and very helpful I want to no how to fix my pipe work the pipe out off the throttle body is rubbing on the bonnet and the inter cooler seem huge and the kn filter is pushing my light out .its seems that it is a doggy set up any help would be great thanks ian Link to comment Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 16y 1m 11d Gender: Male Location: Vic Posted 19/08/12 06:15 AM Share Posted 19/08/12 06:15 AM You have two options, a process west crossover replacement, which will tidy it up. Or a replacement cold side pipe that goes the other way and under the headlight. Link to comment Share on other sites More sharing options...
cjsxrt Donating Members 145 Member For: 15y 4m 18d Posted 19/08/12 06:23 AM Share Posted 19/08/12 06:23 AM Or if you have stock cross over you can use that I've done that the same type of pipe work and cut the stock cross over down and looks pretty good Link to comment Share on other sites More sharing options...
freeze_dk I am dissatisfied with my current employment situation Donating Members 8,610 Member For: 17y 7m 3d Gender: Male Posted 19/08/12 06:43 AM Share Posted 19/08/12 06:43 AM Just bash the pipes bottom flat,, dodjy but you wont see it Link to comment Share on other sites More sharing options...
ian69 Bronze Donating Members 31 Member For: 11y 9m 16d Posted 19/08/12 07:06 AM Author Share Posted 19/08/12 07:06 AM thanks fellers I think I will give the process cross over pipe a go looks clean and hopfuly wont need to change to much .thanks but I dont think ill hit the pipe with a hammer the hole set up on the thottle body is dogy so I will be able to fix that with the crossover kit is there any think I can do to stop the air filter pushing my fog light out maybe cut some off the panel out behind it and move it back Link to comment Share on other sites More sharing options...
Stazza_Brendan Donating Members 686 Member For: 14y 6m 20d Gender: Male Location: Mackay QLD Posted 19/08/12 07:23 AM Share Posted 19/08/12 07:23 AM You need to bend or cut the panel that the filter is up against so the whole intake can be pushed back towards the turbo a bit. Link to comment Share on other sites More sharing options...
ian69 Bronze Donating Members 31 Member For: 11y 9m 16d Posted 19/08/12 07:48 AM Author Share Posted 19/08/12 07:48 AM You need to bend or cut the panel that the filter is up against so the whole intake can be pushed back towards the turbo a bit.thanks will have a look at that 2 morro Link to comment Share on other sites More sharing options...
ian69 Bronze Donating Members 31 Member For: 11y 9m 16d Posted 28/08/12 09:41 AM Author Share Posted 28/08/12 09:41 AM hay fellers I got my process west cross over pipe can I move the blow off vavle down beteen the battery and the water bottle Link to comment Share on other sites More sharing options...
ian69 Bronze Donating Members 31 Member For: 11y 9m 16d Posted 15/09/12 10:29 PM Author Share Posted 15/09/12 10:29 PM well got it done still need some hose clamps not real neat but better then what it was .still need a elbow to come off eng breather Link to comment Share on other sites More sharing options...
