  • Legacy Donating Member
  • Member For: 17y 1m 18d
Posted
So I've searched the forums looking for the info I require but it seems 95% of guys here run mechanical boost gauges where I plan to run all electronic. Im usin auto meter coalt gauges, boost and oil pressure but Im at a loss as to how to wire the gauges properly. An earth will be easy to find, key on power I'm not sure about and also where to hook the boost sender upto.. Plan to run the wires out of the grommet on the left hand side of the icc, gonna get a speco oil filter adapter for the oil pressure but yeah any help is greatly appreciated
  • Member For: 15y 2m 10d
Posted
Wire the power from the cigarette lighter 12v wire and earth to dash crossbrace or similar, earth MUST be good, boost sender wiring should be integral? My drift gauges were
  • Member For: 18y 4m 19d
Posted
As above just lift the surround up from the shifter starting at the center console pull towards the icc only has 6 clips and there's your power wire. Easiest this way
Posted
Thanks guys, big help, one more thing, where has everyone mounted the boost sender?
  • Member For: 18y 10m 13d
Posted
T piece off of the thin tube running from the BOV on my BFII - stock intake setup.
Posted
Cheers, so one more question, so how is everyone holding their gauges in the holder, I got an saas twin gauge holder but no way to hold the gauges in the holder..
Posted (edited)
Double sided tape, only because the provided long bolts and nuts don't line up through holes in the gauges to the pods. This is inside the pods, from rear of gauges. I don't have the same brand gauges.
Edited by -SteveR-
  • Member For: 16y 8m 19d
Posted
FPV twin mount for the win.
All the wiring can go to the ICC and cig lighter to do your full time power, switching power, and dimming circuit. There are threads with the colours stated. It was just the other day someone was asking which wire on ICC for the power or something like that and I did search out the answer for that thread.
  • 1 year later...
  • New Member
  • Member For: 13y 28d
Posted
I have a question if I was to buy a new set of gauges boost and a new oil pressure gauge will I need to rewire them up or can I some how use the ones that my car has atm want to replace my crap cheap ones now I have the $$$ any advice much appreciated cheers.
