Rydeit Member 327 Member For: 14y 2m 21d Gender: Male Location: Adelaide S.A Posted 10/07/12 09:32 AM Posted 10/07/12 09:32 AM Hi everyone. Finally saved up enough to buy a ba mk ii typhoon. It's manual with 110,000 on the clock and in immaculate condition inside and out. Currently has 270 rwkw from a tune, 60lb injectors, turbo smart blow off valve, exhaust turbo back (not sure of dimension). Other then that it is stock and Apparantally running 10psi. The needle never goes past way on the boost gauge. Does anyone know if that relates to 10 psi. And also what mods should I be looking at next only looking for around 340rwkw and don't want to spend heaps at the moment. Cheers
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Legacy Donating Member 9,946 Member For: 18y 6m 11d Gender: Male Location: Vic Posted 10/07/12 09:36 AM Posted 10/07/12 09:36 AM Just a decent cooler kit and retune will see 340
rbjet Skid Machine Legacy Donating Member 1,640 Member For: 15y 4m 7d Gender: Male Posted 10/07/12 09:58 PM Posted 10/07/12 09:58 PM Henz in on the money there. Grab a cooler kit and intake off one of the sponsors and then a retune should get you 300+ pretty easily.
Rydeit Member 327 Member For: 14y 2m 21d Gender: Male Location: Adelaide S.A Posted 11/07/12 05:32 AM Author Posted 11/07/12 05:32 AM Ok to easy any Recomendations for which intercooler or air intake to go for? And does anyone know what the values are for the standard boost gauge. Tried a search but didn't get any decent results
rbjet Skid Machine Legacy Donating Member 1,640 Member For: 15y 4m 7d Gender: Male Posted 11/07/12 05:50 AM Posted 11/07/12 05:50 AM Plenty out there. Plazmaman,Process West, Rapid, Nizpro. All of them are good.Not too sure how the factory boost gauge reads. Could be up to 1bar (14.7psi)?
Rydeit Member 327 Member For: 14y 2m 21d Gender: Male Location: Adelaide S.A Posted 11/07/12 07:46 AM Author Posted 11/07/12 07:46 AM I have heard heaps about plazmaman so might head down that track. Currently using an stc hand tuner no idea how to use it though
Slash Donkey Dick Member 801 Member For: 16y 6m 12d Gender: Male Posted 11/07/12 08:18 AM Posted 11/07/12 08:18 AM You'll need to complete that fuel system too. Chances are you already have an intank walbro, so most cost effective solution in my opinion would be a cheap generic 1L swirl pot off eBay, some rubber fuel line with push-lock fittings to go from tank to swirl pot & swirl pot to existing fuel lines, and a bosch 044 pump (with necessary relay & wiring). If you're handy with spanners & a soldering iron, this can be installed for less than $450
Rydeit Member 327 Member For: 14y 2m 21d Gender: Male Location: Adelaide S.A Posted 11/07/12 10:00 AM Author Posted 11/07/12 10:00 AM Thanks for the replys. Going to go find a decent air intake setup, front mount, boost controller followed by a retune. Hopefully should see a reliable 300+rwkw
rbjet Skid Machine Legacy Donating Member 1,640 Member For: 15y 4m 7d Gender: Male Posted 11/07/12 09:45 PM Posted 11/07/12 09:45 PM You won't need an aftermarket boost controller so you can save yourself a couple of bucks there and put it towards other mods.
Rydeit Member 327 Member For: 14y 2m 21d Gender: Male Location: Adelaide S.A Posted 12/07/12 02:06 AM Author Posted 12/07/12 02:06 AM Only reason I wanted after market boost controller was so I can up the boost when needed. You recon it's not worth it?
