May 20, 201214 yr #1 Hey there, another post from me, my horn doesn't work, come up with a relay code on scantool, replaced relay, press horn and relay is clicking, so must be horn itself, where are they situated?? Thanks,.
May 20, 201214 yr #2 did you try the fuse?you will have 2 horns, take the front bar off and you can't miss them
May 20, 201214 yr #5 Mine didn't work.. Replaced Relay, Replaced Fuse.. No Dice.. Did you clear the code on the scan tool? Cause that's all ford had to do to get it working apparently..
May 20, 201214 yr #6 when I was young and foolish installing my very first cooler I had to move mine and I foolishly put it back in with horns facing up, they worked until the first wash and filled with water and were both farked, new horns from ford were only about $50 from memory...
