April 29, 201214 yr #1 hi guys first post! I've got a fg tuned to 12psi xforce xhaust and coolerworx pipes. when I floor it my boost gauge snaps to -20 vac and goes nowhere. if I squirt it normal it will still boost pretty normal showing 5-10psi and feels good? I thought if I had a boost leak the vac would still go to zero or am I wrong? thanks Edited April 29, 201214 yr by g6efun
April 29, 201214 yr #2 Could be a leak in the vac itself or faulty boost gauge. Does the car still continue to accelerate normally when this happens?
April 30, 201214 yr #3 Author it feels slow like theres no turbo but continues to rev out. what do you mean there could be no vac?
April 30, 201214 yr #6 Sounds like you've busted a pipe off somewhere mate, the pipes have been changed so go over all of the joins and make sure the clamps are all done up tight
April 30, 201214 yr #7 no if hes getting boost under part throttle.id be doind some datalogging and paying attention to the the map value and and torque limit requests
April 30, 201214 yr #8 Is the car turbo?Haha, good question Tuned to 12psi so I guess sosenna_T could be on the money Edited April 30, 201214 yr by riptide
May 1, 201214 yr #9 I would then expect 0 at WOT not -20. so im thinking the ECU is commanding the T/B closed , we need more explation on "goes nowhere"
May 2, 201214 yr #10 Elaboration is the key here, like most questions asked on any forum we can guess all day but without a bit more info who knows
