  • Legacy Donating Member
  • Member For: 14y 6m 6d
Posted
Hi guys,
I've got a BF I and after giving it a couple of squirts this morning it seemed to increase in engine temp from just over a third to just over about three eights. Picked it up from the mechanic this arvo and same thing after a squirt.
Is this just general engine temp or is the turbo heating something?
Where does everyone else's sit?
Also I remember from years ago some guys were putting spacers under the nuts at the rear of the bonnet so that there was a slight gap between the rear edge of the bonnet and the cowl which would draw air from the engine bay out. Has anyone done anything like this or do you think this would work?
Not in the market to get some sort of vented bonnet just yet.
Any ideas?
  • Skid Machine
  • Member For: 15y 4m 15d
Posted
Those temps sound pretty normal mate. Instead of putting in washers for spacers you could try removing the rubber strip under the bonnet at the bottom of your windscreen.
  • Skid Machine
Posted
I did do 3 laps at Winton and the temp gauge goes off the clock.
  • 09JET
  • Member For: 17y 3m 19d
Posted
If you have a big fat cooler at the front it might be worth putting a slightly cooler thermostat in.
  • Skid Machine
Posted
I wish I had of done that before my tune. It's kind of pointless with out a tune though isn't it Rhino?
  • Member For: 19y 5m 23d
Posted
2nd vote for removing the rubber stri, not a HUGE difference but does let a fair bit of heat out...
  • Moar Powar Babeh
  • Member For: 21y 16d
Posted
No problems with the windscreen fogging up once the strip is removed?
  • 09JET
Posted (edited)
I cant see how it would affect your tune at all. It just opens the thermo a little earlier ie at a lower temp, compensating for the reduction in airflow to the radiator by jamming a big intercooler in front of it. Happy to be corrected though.
Edited by Rhino1980
