Chloexr6t Member 12 Member For: 16y 2m 15d Gender: Female Location: Penrith Posted 30/03/12 04:37 AM Share Posted 30/03/12 04:37 AM Heys GuysAfter tuning my FG F6 should the spark plugs be re gapped Link to comment Share on other sites More sharing options...
Rhino1980 09JET Member 1,510 Member For: 14y 10m 9d Gender: Male Location: E. Maitland Posted 30/03/12 04:49 AM Share Posted 30/03/12 04:49 AM Yep. Increased boost may blow the spark out, just like in a higher compression methanol engine. Your tuner should do it for you as part of the service. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m 5d Gender: Male Location: Perth Posted 30/03/12 05:16 AM Share Posted 30/03/12 05:16 AM Yes and or no. As Rhino said you need a smaller gap for higher boost pressure. However it is more desirable to fit the correct plugs with the correct gap. Modern plugs aren't designed to be regapped and regapping then can leave you with a ground bar the isnt square to the electrode, which hurts the plugs performance.Didn't i read somewhere that FG F6's had .9mm gap factory? Link to comment Share on other sites More sharing options...
Chloexr6t Member 12 Member For: 16y 2m 15d Gender: Female Location: Penrith Posted 30/03/12 05:23 AM Author Share Posted 30/03/12 05:23 AM I am still running the same boost as standard. What gap have you guys changed too. Link to comment Share on other sites More sharing options...
Rhino1980 09JET Member 1,510 Member For: 14y 10m 9d Gender: Male Location: E. Maitland Posted 30/03/12 07:06 AM Share Posted 30/03/12 07:06 AM 0.48 if I recall correctly but that seems smaller than what a lot of people posted theirs as in a similar thread. IIRC most were 0.6 - 0.7. I wouldn't bother with standard boost, but your sig says 348 RWKW that would need about 16 pound give or take. Link to comment Share on other sites More sharing options...
Chloexr6t Member 12 Member For: 16y 2m 15d Gender: Female Location: Penrith Posted 30/03/12 07:28 AM Author Share Posted 30/03/12 07:28 AM thanks the car has already been tuned to 348rwkw and is only running 14psi Link to comment Share on other sites More sharing options...
Rhino1980 09JET Member 1,510 Member For: 14y 10m 9d Gender: Male Location: E. Maitland Posted 30/03/12 10:23 AM Share Posted 30/03/12 10:23 AM Are you having problems with it misfiring or anything? What does the boost spike to if at all before it settles to 14? Link to comment Share on other sites More sharing options...
james333 Member 91 Member For: 13y 2m 13d Gender: Not Telling Posted 06/04/12 01:07 AM Share Posted 06/04/12 01:07 AM I would only regap the plugs if the engine starts to miss fire under WOT.You will lose economy and power the smaller the plug gap gets. Link to comment Share on other sites More sharing options...
Chloexr6t Member 12 Member For: 16y 2m 15d Gender: Female Location: Penrith Posted 08/04/12 03:21 AM Author Share Posted 08/04/12 03:21 AM Thanks Guys. No I haven't had any problems with misfire so I will just leave them until or if it does. My boost doesn't spike at all full boost is about 14.5psi Link to comment Share on other sites More sharing options...
