Air Mix Shaft Or Him?
Featured Replies
#1
Hi Guys,
I know this is probably a common issue as I have googled so much lately !! however my heater isnt working in my 2004 BA mk2. I keep reading it could be the air mix shaft, or the HIM module? Is there a way or knowing which one it is before taking out the dash ?? The mixer turns to the left and the air con kicks in, works a treat. turn it too the right ( heat ), nothing happens !!! Can anyone suggest some options to do/look at before I start taking the dash out ?
Greatly appreciate any help !!!!
#2
If its not dual zone and your getting no hot air it will be the mixer shaft
#3
  • Author
yeah its just single zone, no hot air what so ever ! Does the whole dash gota come out or just the centre console ?
#4
Both lol remove centre console then pull dash out, I sit it in the front seats, climb in and rip the him module out, normally thr blendors break as well so the front section of the heater box needs to be unscrewed and removed then it splits un half so you can get the blendors out
#5
What's the deal with the dual zone? Does this still happen or are there other issues.
#6
Yeh its actually easier to tell when it happens to dual zone ones, theres normally a massive temp difference between each side as most of the time only the passenger blendor breaks so when u set it on hot the drivers side goes hot and the passenger side stays cold, as of 10/11 all falcons and territorys have a new HVAC system so this shouldnt happen to new ones
  • 6 months later...
#7
Sorry to dig an old thread.... Do the dual zones have two mixer shafts?
#8
Bionic, when you say from 10/11 the Falc and Terry have a new HVAC system, do you know much about the changes. Is it a redesign or just some upgraded parts.
My 01/09 G6ET has a 10 degree difference between vents and needs the new controller thingo but wondering if the improved controller from 10/11 onwards can be used?? If it can a part number would be good.
#9
The new system isnt interchangable, as far as I understand the entire hvac assembly is different, it also takes more gas<br /><br />Yes dual zone has 2 mixer shafts
Edited by bionicxr6t05
Recently Browsing 0
