Help About Engine Replacement
Featured Replies
#1
I blew the engine in my Falcon it turned out to be bad fuel that blew it... (not happy) anyways I was running 410rwkw through a BF mkII which Iv been told isnt to much drama... anyways when I blew it as you can imagine made a big mess of th e block and the sump.. now Im looking at a new block and I know my next question is gonna sound super stupid.. but I dont want to ask these questions at a mechanic cause they will probaly take advantage of it and charge me a sh*t tin... the engine I have found is a BF mkII block it has had the sump weilded professionally as it had a crack.. will this cause dramas down the road? also it doesnt come with Manifold Wiring, oil pump and accessories.. I dont think I need any of those things anyway right? and If I do what is needed? any help on this is muchly appreciated...
thanks in advance,
Peever.
  • Replies 23
  • Views 2.2k
#2
  • Author
anyone please?? =(
#3
Is that the one on ebay? if so just buy a new sump if your worried, oil pump you should replace anyway with a Atomic one for safety. Wiring cannot help there.
#4
  • Author
yes its the one on ebay.. =) It looks like a pretty good buy... thanks for the help.. can anyone shed some light on the manifold wiring? If Im correct that shouldnt be an issue??
#5
use the one on your car? should work.
#6
  • Author
sweet as.. im not very mechanical minded hence why I wanted to make sure... think Imma go for this one on ebay.. been looking for a few months and not much has come up..
#7
How bad is your engine as ford sell new short motors for about $3000
#8
  • Author
The sump has pretty much disappeared... and the block has a hole on each side the engine will be taken out over the next week or so...
#9
As long head is ok look at the short engine option, being brandnew you know nothing is wrong.
#10
The sump should be fine as long as its not leaking. BFII has stronger pistons, same rods as FG, but FG block is stronger than BF.But a stronger block is not going to make alot of difference when your throwing rods. Cheers
Edited by Impellor
Recently Browsing 0
