December 20, 201114 yr #1 My BA F6 sways around when I am going around 100kms or faster does any one have any idea's what this could be I thought it was wind and road conditions at first but now think different any help would be appreciated thanks
December 20, 201114 yr #4 Wheel alignment would be my first call.. Plus it's cheap to get done.. Other thing that gives a slightly unstable feeling is a buckled rim maybe?
December 20, 201114 yr #5 Not alignment, alignment would just cause it to pull to one side.It's most likely your lower control arm bushes, if not that one of the other bushes in there. It's probably doing it at lower speeds too but bit harder to notice...
December 20, 201114 yr #6 I had the exact same problem... turned out to be one of the bushes in the back near the wheel, was only the rear drivers side wheel that was the cause for me, at 100 it would get the shakes.. easy fix and not too $$$.. If your in Melb I can recommend a place..
December 21, 201114 yr #7 Author Thanks heaps for your input I'm in Sydney and I don't think it's a shake it's like the wheels are spinning but not it doesn't happen all the time it's like the diff is moving from side to side I have lacked it up and put on stands to see if there is any movement but none I'm puzzled
