Bellato Donating Members 2,713 Member For: 14y 8m 25d Posted 14/11/11 11:44 AM Share Posted 14/11/11 11:44 AM Hey guys I'd say this has been asked before but couldn't quite find anything specific. I'm looking at buying a BF (hopefully MKII) xr6t and im not gonna budge on getting a manual so that leaves me very few options. So basically I need to consider buying ones with different kms, Ideally I want something around 80,000 but if you guys think that theres not much maintenance required beyond 100,000kms then I might consider cars with more kms.So basically what I'm wondering is at what kms does certain maintenance need to be done on this model in manual and how much are these services? Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/77777-regular-maintenance/ Share on other sites More sharing options...
P_BA_XR6 Member 271 Member For: 17y 1m 13d Gender: Male Location: Castle Hill Posted 30/11/11 12:07 PM Share Posted 30/11/11 12:07 PM The maintance advise would tighten up/check the turbo bolts every oil change or second if thrash it or once every 30000 would be good IDEa change oil every 10000 and change filter . check to see if spark plugs been changed once u own it, check basically oils (gearbox, diff, clutch and brakes) and coolant and check fuel filter Buy aftermarket oil filter kit from earls or eBay turbos know to fail to not enough oil/ oil line internal filter clogs up Check belts n pulleys once 100000I'm sorta fussy so maybe not everything but defiantly good idea after oil line kit and check turbo bolts which bolts the turbo to the manifold once n awhile turbo get hot enought to cause the nuts to loosen little bit or what I've done double nut Link to comment https://www.fordxr6turbo.com/forum/topic/77777-regular-maintenance/#findComment-1164563 Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 8m 25d Posted 03/12/11 06:57 AM Author Share Posted 03/12/11 06:57 AM Sounds good, thanks mate! Now I just need the car!! Link to comment https://www.fordxr6turbo.com/forum/topic/77777-regular-maintenance/#findComment-1165482 Share on other sites More sharing options...
EvilDaifu Cruise Whore Moderating Team 5,130 Member For: 19y 11m 9d Gender: Male Location: Melbourne Posted 17/06/12 09:50 AM Share Posted 17/06/12 09:50 AM FordXR6Turbo DIY - Manifold BoltsHere's something that is really common - loose exhaust manifold bolts Here "the Doc" shows us where to find these bolts and what he does to maintain them. Thanks mate - this is something I always wanted someone to show me how to maintain Caveat emptor this DIY tip Link back to other DIY maintenance. Link to comment https://www.fordxr6turbo.com/forum/topic/77777-regular-maintenance/#findComment-1255529 Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 21y 10m 9d Gender: Male Location: Southern Highlands NSW Posted 17/06/12 10:17 AM Share Posted 17/06/12 10:17 AM Thread mine much? Link to comment https://www.fordxr6turbo.com/forum/topic/77777-regular-maintenance/#findComment-1255566 Share on other sites More sharing options...
EvilDaifu Cruise Whore Moderating Team 5,130 Member For: 19y 11m 9d Gender: Male Location: Melbourne Posted 17/06/12 11:24 AM Share Posted 17/06/12 11:24 AM Spreadin the luurv baby Link to comment https://www.fordxr6turbo.com/forum/topic/77777-regular-maintenance/#findComment-1255638 Share on other sites More sharing options...
