mic Donating Members 1,725 Member For: 17y 5m 24d Gender: Male Posted 11/11/11 10:43 AM Share Posted 11/11/11 10:43 AM in the line I can hear piston slap when cold, but the pfc doesnt pick it up. but its a dinosoar, lol. Link to comment https://www.fordxr6turbo.com/forum/topic/77706-disconnecting-knock-sensor/page/3/#findComment-1158744 Share on other sites More sharing options...
Mr_4.0 Member 1,096 Member For: 14y 5m 23d Posted 11/11/11 10:56 AM Author Share Posted 11/11/11 10:56 AM That is the plan. Car was last tuned by nizpro 2 years ago. Since then I've had a turbo rebuild, surge tank and new dump pipe added. The nizpro tune was altered, all be it quickly, to suit these changes by a guy here in Geelong. I'm guessing my motor is noisier now than 2 years ago and sensor can hear noise. But yes, a full tune is the plan very very very soon Link to comment https://www.fordxr6turbo.com/forum/topic/77706-disconnecting-knock-sensor/page/3/#findComment-1158748 Share on other sites More sharing options...
rob82 Member 65 Member For: 19y 7m 23d Posted 11/11/11 01:45 PM Share Posted 11/11/11 01:45 PM The idle fluctuation is due to idle proportional spark. It's based off an allowable torque for idle requestor that ramps timing in and out to stabilize the idle. The base idle timing once hot in most cars is referenced from the decel timing map- it should be named "zero apps timing map" the proportional spark is then added to that. This proportional spark is turned off once dashpot idle mode is set - ie above 3mph. As for your high load knock retard I'm yet to see a tuner get this right - it can be achieved thought, even on ba ECM with a built motor and only 1 knock sensor. Link to comment https://www.fordxr6turbo.com/forum/topic/77706-disconnecting-knock-sensor/page/3/#findComment-1158784 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 20y 4d Gender: Male Location: OZ Posted 13/11/11 09:25 AM Share Posted 13/11/11 09:25 AM Cold start though dude :-)Also......HP is missing a vital KS table, so you will never get a decent calibration if you're using that software. Link to comment https://www.fordxr6turbo.com/forum/topic/77706-disconnecting-knock-sensor/page/3/#findComment-1159326 Share on other sites More sharing options...
45T-XR Donating Members 417 Member For: 18y 4m 6d Gender: Male Location: Gladstone, Queensland Posted 14/11/11 10:17 AM Share Posted 14/11/11 10:17 AM Cold start though dude :-)Also......HP is missing a vital KS table, so you will never get a decent calibration if you're using that software.You tell me this after I just paid for my VCM suite today.doh!!! Link to comment https://www.fordxr6turbo.com/forum/topic/77706-disconnecting-knock-sensor/page/3/#findComment-1159638 Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 19y 6m 24d Gender: Male Location: North West Hot Hell,VIC Posted 14/11/11 09:00 PM Share Posted 14/11/11 09:00 PM VCM suite may not have all the tables that sct does but it still works fine.There are plenty of people using it and will be plenty more especially now with SCT round 2.45T-XR you will have fun with your software when you receive it.Put aside alot of time cause youll need it to get your head around it all if you havnt tuned before. Link to comment https://www.fordxr6turbo.com/forum/topic/77706-disconnecting-knock-sensor/page/3/#findComment-1159730 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 19d Gender: Male Location: Perth Posted 14/11/11 11:43 PM Share Posted 14/11/11 11:43 PM Cold start though dude :-)Also......HP is missing a vital KS table, so you will never get a decent calibration if you're using that software.You tell me this after I just paid for my VCM suite today.doh!!!With Mr Toads assistance, Im working on getting this corrected as we speak Link to comment https://www.fordxr6turbo.com/forum/topic/77706-disconnecting-knock-sensor/page/3/#findComment-1159765 Share on other sites More sharing options...
Mr_4.0 Member 1,096 Member For: 14y 5m 23d Posted 15/11/11 06:00 AM Author Share Posted 15/11/11 06:00 AM Well got a new knock sensor. Left mine in the block. Plugged new one to my loom and cable tied it off. It seems our ecu requires some "noise" to be deemed working so th ecu threw a code. Top end timing was still getting pulled down to 7 degrees even as low as 14psi. So knock sensor is not the issue. My datalogs show intake temp, coolant temp, oil temp and head temp all appear normal. I'm confused. Link to comment https://www.fordxr6turbo.com/forum/topic/77706-disconnecting-knock-sensor/page/3/#findComment-1159854 Share on other sites More sharing options...
Mr_4.0 Member 1,096 Member For: 14y 5m 23d Posted 16/11/11 12:55 AM Author Share Posted 16/11/11 12:55 AM Have been speaking with IH8TOADS. Have found that on full throttle my coolant temp sensor reads zero until I back off accelerator. I checked some logs from months ago and the same thing occurs. This would not help my cause. Anyone have any tricks or tool ideas for changing out coolant temp sensor? I've never attempted one haha. Link to comment https://www.fordxr6turbo.com/forum/topic/77706-disconnecting-knock-sensor/page/3/#findComment-1160162 Share on other sites More sharing options...
Mr_4.0 Member 1,096 Member For: 14y 5m 23d Posted 16/11/11 05:51 AM Author Share Posted 16/11/11 05:51 AM My coolant temp sensor spins in the hole. I'd say its rooted. Link to comment https://www.fordxr6turbo.com/forum/topic/77706-disconnecting-knock-sensor/page/3/#findComment-1160210 Share on other sites More sharing options...
