helbz Member 176 Member For: 14y 2m 12d Posted 19/10/11 12:41 PM Share Posted 19/10/11 12:41 PM (edited) I have an XFORCE stainless dump and XFORCE mild steel cat back and it seems to grow after giving it a good run and it knocks and moves around and as soon as I take it easy it seems to cool and stop knocking. Anyone else have a similair problem ? Do I need to replace the exhaust mount rubbers to some H Blocks, Could something be loose ? Something isn't right ! just wanting some info before I crawl under the beast for a look see. Edited 19/10/11 12:46 PM by helbz Link to comment https://www.fordxr6turbo.com/forum/topic/77449-exhaust-growth/ Share on other sites More sharing options...
STAINLESS again plz You've changed man.... Donating Members 8,142 Member For: 14y 5m 26d Gender: Male Location: 2 Fuchsia Court, Narre Warren. 3805 Posted 19/10/11 08:06 PM Share Posted 19/10/11 08:06 PM 4"? Link to comment https://www.fordxr6turbo.com/forum/topic/77449-exhaust-growth/#findComment-1151479 Share on other sites More sharing options...
234Fpv Donating Members 522 Member For: 13y 11m 14d Gender: Male Location: Yeppoon qld Posted 19/10/11 10:03 PM Share Posted 19/10/11 10:03 PM When you fitted the system did you push all the heat shield up to give the exhaust more room? Link to comment https://www.fordxr6turbo.com/forum/topic/77449-exhaust-growth/#findComment-1151502 Share on other sites More sharing options...
Tobey Awesome... Member 407 Member For: 14y 11m 17d Gender: Male Posted 19/10/11 10:48 PM Share Posted 19/10/11 10:48 PM Dont have any issues with my turbo back system... Link to comment https://www.fordxr6turbo.com/forum/topic/77449-exhaust-growth/#findComment-1151510 Share on other sites More sharing options...
helbz Member 176 Member For: 14y 2m 12d Posted 20/10/11 03:07 AM Author Share Posted 20/10/11 03:07 AM 4"?Yes 4 inchWhen you fitted the system did you push all the heat shield up to give the exhaust more room?I didnt fit the exhaust and which heat shield do mean exactly mate ? Link to comment https://www.fordxr6turbo.com/forum/topic/77449-exhaust-growth/#findComment-1151595 Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 5m 4d Gender: Male Location: Christchurch, New Zealand Posted 20/10/11 03:19 AM Share Posted 20/10/11 03:19 AM I have an xforce dump to twin 2.5 and found it would knock if loaded up in cornering. So I have since had a sideways mount added at the very tail end of the exhaust as there was a huge amount of sideways movement. I also added a solid mount from a gearbox bellhousing bolt (had heaps of thread sticking out) to the dump pipe as there was only about 5mm or less gap between that and the bellhousing.No more knocking now. Think it was knocking below the driveshaft hanger against the chassis. Link to comment https://www.fordxr6turbo.com/forum/topic/77449-exhaust-growth/#findComment-1151597 Share on other sites More sharing options...
234Fpv Donating Members 522 Member For: 13y 11m 14d Gender: Male Location: Yeppoon qld Posted 20/10/11 05:15 AM Share Posted 20/10/11 05:15 AM The heat shield that goes above the exhaust over the diff. If that isn't pushed right up it will hit. Link to comment https://www.fordxr6turbo.com/forum/topic/77449-exhaust-growth/#findComment-1151638 Share on other sites More sharing options...
STAINLESS again plz You've changed man.... Donating Members 8,142 Member For: 14y 5m 26d Gender: Male Location: 2 Fuchsia Court, Narre Warren. 3805 Posted 20/10/11 05:44 AM Share Posted 20/10/11 05:44 AM +1 for mount off gearbox. Does it only knock when turning left?Also mild steel doesnt grow as much as stainless so your lucky there. The knocking wont be the dump pipe, it will most likely be the cat hitting the body. What happens is as it heats up, the bends open up. Picture your arm/elbow 90 degrees. Then straighten it out slightly simulating the zorst opening when hot. If u can take this into consideration then get under your car and visualise this happening, you can work out where things are moving. Link to comment https://www.fordxr6turbo.com/forum/topic/77449-exhaust-growth/#findComment-1151647 Share on other sites More sharing options...
1600dave Donating Members 872 Member For: 14y 5m 12d Posted 20/10/11 06:00 AM Share Posted 20/10/11 06:00 AM I have a 2x2.5" Xforce system on my BF sedan, knocks turning left. Looking from the rear, it sits way to the right of the exhaust cutout.The stock rubber's holes are way to big for the xforce hangers too.I was told when it was fitted that quite often xforce exhausts need modifying/slight bending to get a nice fit.I'm not real fussed by it anymore. Link to comment https://www.fordxr6turbo.com/forum/topic/77449-exhaust-growth/#findComment-1151657 Share on other sites More sharing options...
CBXRT Banned 643 Member For: 14y 6m 30d Gender: Male Posted 20/10/11 06:05 AM Share Posted 20/10/11 06:05 AM Stainless, not saying you are wrong mate but steel shouldn't change shape surely? Never heard of that with a car before. Get very hot yes, more pressure in the system yes, but not warped steel surely.I would think this is more a knock of a shield due to poor fitting which XForce are renowned for (or poor mounting), but happy to be proved wrong as I'm not a metalwork genius!! Link to comment https://www.fordxr6turbo.com/forum/topic/77449-exhaust-growth/#findComment-1151660 Share on other sites More sharing options...
