Blown Engine
Featured Replies
#11
knoath its making me nervous :buttonit:
  • Replies 108
  • Views 12.2k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • bionicxr6t05
    bionicxr6t05
    What a load of sh*t lazybrennan, im a mechanic an a ford dealer mechanic at that and on the rare occasion that we f*ck up we go absolutely out of our way to rectify the problem and ensure the customer
  • sexual harrassment panda
    yep, mine had a rag left in the pipework, resulted in a few bent turbo fins, I was in brissie for work and they rang up and told me what had happened, got a loaner car until the turbo core was replace
  • Hey guys had the court hearing today with Intune Motorsport from Seven Hills. And after a 2 hour hearing the f*ck wit turned around to the judge and said this is a big scam . Ali and I nearly fell off
Posted Images
#12
  • Author
the hard thing is getting these second class mechanics to take responsibiltiy for there bad work .
They all seem to blame someone or something else.
This guy who im dealing with tried to tell me that a rag in the engine would not cause this kind of damage it would cause a bad knocking noise and bearing problems with the cams.
#13
Nizpro did exactly the same thing to a customers car. They accepted full responsibility and covered the replacement engine. I believe they even put a higher spec engine in as the replacement.
#14
Saw your car on the dyno today..looks good under the hood
#15
  • Author
cheers mate just got it back happy happy happy.
Ali never lets people down....
#16
Good stuff..did he just give you a running in tune.
What did you end up doing with the bottom end?
#17
  • Author
went with FG f6 engine with billet oil pump and engine oil cooler.
gone with a very safe tune of 365 @ 16psi 1000nm so pretty good.
next will be surge tank and exhaust as I still have standard dump pipe and e85 tune.
then it should be turning out some big numbers..
  • 5 months later...
#18
  • Author
A little up date about my situation after going through all the bull sh*t trying to get this mechanic to face up to his stuff up's
it has not worked, booked a date in court next week where all the evidence will be put forward and hopefully justice will finally be done once the case is over ill post all the pics of the engine and also tell everyone how this mechanic is and they can make there own minds up after that.
#19
You want to play prepare to pay its a 10 year old car standard motor 385rwkw and you want to take the mechanic to court LOL. Oh I forgot is an FPV they last forever.
#20
Am very interested to see how this goes
Recently Browsing 0
