tturbo 6 Member 3 Member For: 15y 4m 21d Posted 14/05/11 01:34 PM Posted 14/05/11 01:34 PM --------------------------------------------------------------------------------HI all I have a TTG and it has a slight misfire but not when is driven in neutral or park and only under 2 -2 and a half grand rev's. I might add there is no misfire that I can hear when car is cold and warming up this is only when car is warm to hot and it does not happen all of the time . today I took it to a friends house how has a scan tool not a cheap basic one this is about $10,000 and what do you know it make a goose out of me and does not do it . have changed to good iridum plugs petrol not gas ones and gaped at 0.9 still has problem. was told by another friend to try the resistance on each of the coil packs with multie meter not to sure if I did this correct or not but this is what I ended up with and how I did it . I put one end - on the spark plug side of coil pack and + one to one side at a time to where the power goes to coil packs the all said about 5.41 and two of them said 5.35 and 5.38 they seem to be not to bad . But I would not know shxt from clay when it comes to that . Have got 5 bad codes back after scan tool (1) B1251 AIR TEMP INTERNAL SENS OPEN CKT (2) B1719 OUTO LAMP SENS IN PUT CKT OPEN (3) 2073 SEAT MEMORY MDUAL DATA LINE OPEN OR SHORT TO GROUND (4) 2075 SEAT MEMORY MODUAL ENABLE LINE OPEN OR SHORT TO GROUND (5) 1348 HEAT BACK LIGHT RELAY OPEN (6) 1947 CLIMAT CONTROL A/C EVAP SENS GROUND SHORT . this he told me did not seem like no big deal so we copy the faults and then clear the and se what comes up again and we only get (1) B1251 and (2) B1791 . THESE TOOLS ARE ONE OF THE BEST OUT THERE WHY DOES IT NOT PICK UP THAT THE CARS MISFIRE . does anyone know how to test coil packs correct or is there a big error margin . Iam going to change petrol filter tonight I dont think it that but its due any way cant hurt .Has any one had or know of any thing like this I would love to hear from you . I AM THINKG MAS AIR FLOW SENSER . thanks for your time every one (ta) I have changed coil packs x6 new platinum plugs correct gap x 6 new . I have tried inlet leak test alls good .Have noticed the car in the morning is cold start up no misfire when it becomes running temp slight misfire is heard at idle to 2;500 rpm if I turn car off and start it back up it will not do it for the first minute or two . (WTF) Any ideas would love to hear from you .This does not affect the cars drive goes great I think running gear is the same as bf turbo . does any one thing have the pcm updated would help thanks for you time .
mitchg911 Member 22 Member For: 17y 5m 16d Posted 15/05/11 11:15 AM Posted 15/05/11 11:15 AM I know it doesn't help, but mine does the same. Bf Turbo, 60lb dekas, pipework etc.. plugs are bkr6e at 0.8mm gap. Mine misses at idle upto about 3k in neutral or park. Only slight.. but definately there..
Gasman Ford Nub Member 412 Member For: 15y 5m 27d Gender: Male Location: Gold Coast Posted 16/05/11 08:04 AM Posted 16/05/11 08:04 AM (edited) did you notice any oil in the plug tubes? Mine had a bit in there and on the coils after clearing the oil out it idled a lot smoother. most likely not the same thing though as you have already changed plugs and coils. Edited 16/05/11 08:08 AM by Gasman
kane Member 5 Member For: 15y 7m 29d Posted 16/05/11 10:49 AM Posted 16/05/11 10:49 AM my manual 03 T does the same thing, it has unichip computer, exhaust, injectors and CAI.when pulling up to a set of lights its almost as if you have to catch the revs before they drop off too far or it will stall
ebxmple Member 1,322 Member For: 18y 8m 4d Posted 16/05/11 11:03 AM Posted 16/05/11 11:03 AM Does his scan tool have a power balance function? Easiest way of seeing which cylider is playing up. I think most cars that have bigger injectors and gapped plugs develop a slight missfire feel at idle though. Might be a problem but might be normal.
IH8TOADS Legacy Donating Member 3,618 Member For: 21y 2m 27d Gender: Male Location: OZ Posted 18/05/11 10:03 AM Posted 18/05/11 10:03 AM For people with gapped plugs and bigger injectors, 90% of the time your tuner can fix this in 5 min. I suggest you tell them it's got a miss at idle.
tturbo 6 Member 3 Member For: 15y 4m 21d Posted 18/05/11 01:51 PM Author Posted 18/05/11 01:51 PM Thanks for the reply hope it normal mine and two others have the same thing . You would of thought some one would of noticed this in the turbo 6 before . OUT of every one that has a turbo 6 have a listen for your self and let us know what you think (ta)
nang3 12" member Legacy Donating Member 2,107 Member For: 21y 3m 11d Location: Perth WA Posted 18/05/11 02:09 PM Posted 18/05/11 02:09 PM mine was doing similar.. cleaned the TB, replaced both TPS's and it ended up being a tiny split in the inlet manifold gasket IIRC..
tturbo 6 Member 3 Member For: 15y 4m 21d Posted 22/05/11 10:36 AM Author Posted 22/05/11 10:36 AM mine was doing similar.. cleaned the TB, replaced both TPS's and it ended up being a tiny split in the inlet manifold gasket IIRC.. Hi this is normal 4 times TTURBOS and they all do the same thing as standard.... Thanks for reply. Let me know what you think . Thanks
