Davidxr6t03 Member 58 Member For: 15y 5d Posted 10/05/11 06:51 AM Author Share Posted 10/05/11 06:51 AM I had a similar issue with my 03 BA Xr6t. Took it too fraud they diagnosed dead pcm. I did as I suggested above and worked through all the earth and power feeds. Found a loose engine earth strap and a Loose pin in one of the BEM plugs. Fixed both those issues and the fault never came backWhat is a BEM plug?Thanks Link to comment https://www.fordxr6turbo.com/forum/topic/74718-car-shutting-down/page/2/#findComment-1104653 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 27d Gender: Male Location: Perth Posted 10/05/11 06:54 AM Share Posted 10/05/11 06:54 AM Body Electronics Module. Located under the Icc behind the tissue box. Its part of the Can Bus coms circuit in these cars.Usually a good place too start if your getting coms errors, but a bad earth/power feed will also cause coms errors and the connections can drop out as the voltage drops due to bad earth/power Link to comment https://www.fordxr6turbo.com/forum/topic/74718-car-shutting-down/page/2/#findComment-1104655 Share on other sites More sharing options...
Davidxr6t03 Member 58 Member For: 15y 5d Posted 10/05/11 07:02 AM Author Share Posted 10/05/11 07:02 AM Is there a DIY how to remove/get to it?Thanks Link to comment https://www.fordxr6turbo.com/forum/topic/74718-car-shutting-down/page/2/#findComment-1104667 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 27d Gender: Male Location: Perth Posted 10/05/11 07:21 AM Share Posted 10/05/11 07:21 AM http://www.fordxr6turbo.com/forum/index.php?app=core&module=search&do=search&fromMainBar=1Have a look through these threads and the AV forum Link to comment https://www.fordxr6turbo.com/forum/topic/74718-car-shutting-down/page/2/#findComment-1104677 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 23d Gender: Male Location: @ my laptop Posted 10/05/11 09:21 AM Share Posted 10/05/11 09:21 AM Ecu's are become to fail in these cars, got another in the shop at the momment, my usual electronics people will not even reco them because they can not gaurantee them. Link to comment https://www.fordxr6turbo.com/forum/topic/74718-car-shutting-down/page/2/#findComment-1104733 Share on other sites More sharing options...
jdcustom Member 44 Member For: 16y 7m 11d Gender: Male Posted 10/05/11 11:36 AM Share Posted 10/05/11 11:36 AM who u use for computers mick?? logicar?? there a bunch of useleess prickshad a vito van here 3000rpm limit, been everywhere, went to merc dealer etc, not find problemsend computer to logicar comes back as tested ok, problem still there!!send computer to injectronics in hallam they repaired it runs fine revs right out now!!and that's only one example ive had from them Link to comment https://www.fordxr6turbo.com/forum/topic/74718-car-shutting-down/page/2/#findComment-1104820 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 6m 28d Gender: Male Location: SE Melbourne Posted 11/05/11 02:35 AM Share Posted 11/05/11 02:35 AM Are the ecu's failing because they sit in the engine bay where exposed to condensation and excessive heat and not behind the dash? Link to comment https://www.fordxr6turbo.com/forum/topic/74718-car-shutting-down/page/2/#findComment-1104928 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 23d Gender: Male Location: @ my laptop Posted 11/05/11 03:50 AM Share Posted 11/05/11 03:50 AM Apparantly they crack solder joints on the circuit board, they used to repair them, but then they would crack in another spot and buyers expecting warranty, so they have figured they do not want to deal with them anymore. Link to comment https://www.fordxr6turbo.com/forum/topic/74718-car-shutting-down/page/2/#findComment-1104943 Share on other sites More sharing options...
Davidxr6t03 Member 58 Member For: 15y 5d Posted 11/05/11 11:50 AM Author Share Posted 11/05/11 11:50 AM Thanks Ratter, Ecu is getting replaced tomorrow, so fingers crossed Link to comment https://www.fordxr6turbo.com/forum/topic/74718-car-shutting-down/page/2/#findComment-1105111 Share on other sites More sharing options...
robbo k Member 414 Member For: 17y 2m 12d Location: Wollongong Posted 13/05/11 11:59 AM Share Posted 13/05/11 11:59 AM No, it will idle perfect until you go to drive it.Thanksyeah used to happen to me as soon as you put the foot on the gas it died. became very bad to drive on the roadApparantly they crack solder joints on the circuit board, they used to repair them, but then they would crack in another spot and buyers expecting warranty, so they have figured they do not want to deal with them anymore.sounds like xbox lol I found the ecu to be abit exposed to some other makes of cars. I know when I pulled one out a of ls1 ute was in the plastic box over it so nothing could leak or sit on it. Link to comment https://www.fordxr6turbo.com/forum/topic/74718-car-shutting-down/page/2/#findComment-1105710 Share on other sites More sharing options...
