  • Member For: 14y 8m 3d
Hi everyone,
Just a bit of a problem, 06 bf force 6
had a 90,000 km service at ford part of that was new plugs.
They put plugs in that had a .9mm gap and the car went better than ever for a while but after 10,000km its slowly dropped power. recently it was misfiring on a cal under high rpm high load conditions. being rather naive I went in and asked for 6 plug and came out with plugs that have a .7mm gap, put em in and car is worse again, feels a bit flat and the same misfire.
Today we gapped the new plugs to .9mm again and basically we have more misfire, boost at about 8 psi (should do 15) and a good 10 seconds for the car togo 5000 - 6000 rpm in 3rd gear. The engine light came on but when tried to read the code with the flash tuner, there was no code there and the light had already gone out.
How do I test the stock coils and is there any replacement aftermarket alternative that is a better option,
what spark plugs work for people and what is the appropriate gagap is there anything else I should be looking at?
Car has tune, 15psi, fuel pump, injectors, cooler pipes, dump pipe and cacatchers any help appreciated
https://www.fordxr6turbo.com/forum/topic/74499-ignition-breaking-down/
  • UNDERCOAT CRUISER!!!
  • Member For: 16y 4m 8d
NGK BKR6EIX these are gapped at .8 also replacement factory coils off ebay are about $160 a set,also maybe change your fuel filter.? :icon_ford:
  • Dropping a turd
  • Member For: 17y 6m 28d
Sounds like you have a dud coil. Borrow a set off a mate and go for a spin. If all is well start replacing his with yours one at a time until the misfire returns and then replace the dud coil with a new one. Or once you have worked out if its the coils buy a brand new set off ebay for $150. Just re-gap the .9 plugs to .8 and they will be fine.
Good point FPV6T if your fuel filter hasnt been changed, its well overdue at 90K.
Edited by arronm
I forgot to mention I bought a new coil, I will try swapping them out. It's a bit of a pain in the ass makes me think easier replacing the whole lot rather than pulling piping and that top cover with it's rear most bolt I cannot get to easily!
  • Dropping a turd
Each time you go for a test drive you only put a couple of bolts back in. You need a 1/4 inch socket hex and rachet for the rear bolt.
  • Member For: 17y 6m 16d
From memory you can test the coils resistance with a multimeter, some one here will know how. There may also be a white track/trace marks down the side of the coil leg where its been breaking down.
Ok I have success!
Changed the coils and plugs again! and car still was the same. I started looking at other things and decided to check the cat.
Oh hello metal part inside the cat hs blown down and become wedged sideways against the rear o2 sensor...
pulled the sensor out and with a screwdriver through the hole managed to push the guts of the cat back up and then using a wire with a hook pulled it back up and out of the exhaust pipe.
So its all good...
My next question is what are the concequences of running no cat for a while till I get a new one?
Car runs REAL well now hahaha
I tested the coils for resitance, I didnt really know what I was looking for, 5.38 ohm across theprimary and secondary and .12 ohm primary to ground. would be interesting if someone has a dead coil that could measure.
