  • Member For: 17y 9m 21d
Posted
I Have a xD ute build on the go! DOHC turbo nearly all done except the wiring.
High mount 6 boost manifold, Plazmaman plenum, Surg tank, Twin 044 fuel pumps, 60lb injectors, Water meth injection, 60mm Pro gate, 2" screamer pipe 6speed and a mall wood opt.3 plus and a LSD 9" diff.
I am running the bf gauge cluster and icc!
How do I go about linking the PCM to the BEM and remove all the anti theft, ABS, tration control, belt lights, Buzzer, ECT. I will not be using the BF steering column so the smart key thing will be a issue as well!
Any help appreciated :bowdown:
post-33020-0-36198200-1297848923_thumb.j
  • Legacy Donating Member
  • Member For: 20y 9m 20d
Posted
I think you will find that you may need someone who has access to the ford IDS scan tool to do what your after,Some ford specfic wreckers actually have the IDS as well.Where are you located? There is also a guy on ebay doing loom mods for conversions.
  • Here since the start...
  • Member For: 23y 5m 12d
Posted
I'd be amazed if all that was possible.
I doubt there's an ability to turn all of those features off.
Posted
thanks guys! I live in Emerald Central QLD and the ford dealership here is hopless!!
I hope I can work my way through these problems.
The ebay loom would be good except I am running the hole bf ute wiring loom, just need to patch the xD start and steering controls in Ie. blinkers horn lights ect.
