Jamsey Member 37 Member For: 14y 5m 24d Posted 15/02/11 07:03 AM Share Posted 15/02/11 07:03 AM Hey everyone, me and a mate are working on a burnout/drag mostly burnout car.. we have a toxic green xr6t sedan, ba 1, manual (5speed)its been going pretty good so far (havent done many mods yet, 10 psi generic tune, bigger fmic)but we have been surprised how long this LSD had lasted without spinning a single yet. the car has done 135,xxxkm and im pretty sure its still the original diffso my questions are,These m86 diffs seem to be pretty good, how much abuse do they usually take before they let go? im only used to having the bw78 lsd's in the older models... and they were horrible at taking abuse. and if the lsd starts to fail, are there any places that sell a minispool or lokka for the m86 ( I have looked around without success), or would welding be my only option (hopefully wont need to weld)any help is appreciated. Link to comment https://www.fordxr6turbo.com/forum/topic/73283-diff-options-for-burnout-car/ Share on other sites More sharing options...
dalts Member 755 Member For: 19y 17d Gender: Male Location: brisbane Posted 15/02/11 08:11 AM Share Posted 15/02/11 08:11 AM most diff places ive spoken to will do mini spools,full spools,kaaz centres and true tracs but usually advise against the first two as they are dangerous in a street car..but as yours is a burnout car a mini spool would be a good option as they are very cheap and still strong enough!!cheers lee Link to comment https://www.fordxr6turbo.com/forum/topic/73283-diff-options-for-burnout-car/#findComment-1081323 Share on other sites More sharing options...
Jamsey Member 37 Member For: 14y 5m 24d Posted 15/02/11 12:35 PM Author Share Posted 15/02/11 12:35 PM thanks mate, ill have a look around for a minispool for when/if? it breaks. might to a ratio change while im at it.but im just so surprised how well this LSD is holding up, it hasnt slipped at all yet. even doing burnouts when one wheel going on/off the road it still stays tight. these really are a strong diff, much much better than the old style. Link to comment https://www.fordxr6turbo.com/forum/topic/73283-diff-options-for-burnout-car/#findComment-1081420 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 4m 5d Gender: Male Location: SW Sydney Posted 15/02/11 09:43 PM Share Posted 15/02/11 09:43 PM I'd say you'll have more issues with the T5 box before the diff! 2nd gear normally goes first in those things - chuck a 3spd in it! Link to comment https://www.fordxr6turbo.com/forum/topic/73283-diff-options-for-burnout-car/#findComment-1081464 Share on other sites More sharing options...
scottay Member 366 Member For: 15y 1m 20d Posted 15/02/11 09:52 PM Share Posted 15/02/11 09:52 PM id be more worried about blowing the 5 speed Link to comment https://www.fordxr6turbo.com/forum/topic/73283-diff-options-for-burnout-car/#findComment-1081467 Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 3m 30d Gender: Male Location: Sydney Posted 15/02/11 10:24 PM Share Posted 15/02/11 10:24 PM As others have mentioned the T5 gearbox is by far the weakest link, next would be the CV joints, followed by the tailshaft.The diffs are not often a problem unless the other bits are upgraded and then you run sticky tyres. Link to comment https://www.fordxr6turbo.com/forum/topic/73283-diff-options-for-burnout-car/#findComment-1081474 Share on other sites More sharing options...
Jamsey Member 37 Member For: 14y 5m 24d Posted 16/02/11 12:22 AM Author Share Posted 16/02/11 12:22 AM ok so ill best be spending my money on a t56 then. then ill just fix things as the break. would a dump pipe and cat upgrade be worth while? or are the exhaust pipes also a major restriction? I was planning on getting an exhaust and proper tune, and was told a full exhaust system will get decent results, but getting just the dump and cat would cost ALOT less Link to comment https://www.fordxr6turbo.com/forum/topic/73283-diff-options-for-burnout-car/#findComment-1081489 Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 3m 30d Gender: Male Location: Sydney Posted 16/02/11 01:37 AM Share Posted 16/02/11 01:37 AM Stock exhaust is good for about 300rwkw, if you do the car and dump, you will be able to get more out of the stck syste, as the Cat is the biggest restriction.Will this car be roadworthy ? if not then you can do alot more exhaust mods. Link to comment https://www.fordxr6turbo.com/forum/topic/73283-diff-options-for-burnout-car/#findComment-1081497 Share on other sites More sharing options...
Jamsey Member 37 Member For: 14y 5m 24d Posted 16/02/11 02:50 AM Author Share Posted 16/02/11 02:50 AM yes the car must stay roadworthy, as it is also the back up car for if either me or my mates daily driver isnt on the road, but the car will get minimal driving.I was told by a tuner that he found the defilipo full exhaust and a tune will get me some decent results, so I thought would just the dump and cat be sufficient to change or would the whole exhaust yield SOME extra benefit? Link to comment https://www.fordxr6turbo.com/forum/topic/73283-diff-options-for-burnout-car/#findComment-1081516 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 9m 9d Gender: Male Location: Townsville Posted 16/02/11 12:43 PM Share Posted 16/02/11 12:43 PM I would run it on methanol to give it the best change of keeping cool and living. buy some 80lb injectors maybe and one more bosch 044 inline pump up close to the fuel rail, refill the car with methanol for its meth tune and your done just keep the power down that's all at a reasonable level so it lasts well.They already have plenty of power to rip skids so why have 400rwkw when it isn't needed! Link to comment https://www.fordxr6turbo.com/forum/topic/73283-diff-options-for-burnout-car/#findComment-1081651 Share on other sites More sharing options...
