FG Ute Custom Tray Build
Featured Replies
#631
  • Author
If frame was painted black then id go the dark red timber. But polished frame will look better with a black floor. Its just gettin a bit busy with 3 different colours covering such large areas imo.
Ps. Acrylic/perspex is not gunna happen. Even 10mm will warp in the sun let alone where its only millimeters above the 4" stainless exhaust.
  • Replies 1.3k
  • Views 222.9k
Most Popular Posts
  • Is this done yet @Stink Finger
  • Panda Eyes
    Panda Eyes
    he'll be on in 2 weeks....
  • OZYWALKER
    OZYWALKER
    Will drive to yours if you make me a bitchin tray for my ute, needs side pipes and all to go with it haha. Not donating my ute though.
Posted Images
#632
+1 for perspex above 4 inch exhaust
#633
Lol. Give it some time and it'd look shick! Fully
#634
  • Author
Op had a busy afternoon.
Cut away and capped to give clearance for rear of led strips.
#635
Glad my bed frame is coming along nicely.
#636
Lol. What's with the weld burn (?) In first pic on the side of the frame? :|
#637
just use an alloy sheet ixed from the bottom and paint it gloss black then do the signage staino. or use thin sheet steel but it may warp. also go for a set of allan key head bolts polished to hold the black insert in that would look horny
#638
  • Author
Weld burn happens when you weld shy.
Where that join is will be completely cut out when the tubbs go in.
Pretty much set in concrete now that the flooring has to be 19mm. Final decision will be made after polishing, if polishing comes out as I hope then the deck will be marine ply sprayed black.
If the polishing turns to arse then the frame will be sprayed black and will go dark red decking.
#639
No sh*t Sherlock. I'm meaning did you weld something on that side? You nuff.
Still looks good seeing the whole frame together and how it'll look for size. Tubs going up against the other length of metal going front to back?
#640
  • Author
here shy...
where that join/burn mark is is right where the tubbs are. I made the join there on purpose. You can also see how the tubbs will be attached :spoton: and I like showing off my new found 3d modelling skills haha
Edited by STAINOnegger
Recently Browsing 0
