John_K Legacy Donating Member 438 Member For: 17y 10m 1d Gender: Male Location: Sydney Posted 20/12/10 01:29 AM Posted 20/12/10 01:29 AM Hopefully you sort it before tomorrow mate
nathen ride the lightning Legacy Donating Member 338 Member For: 19y 11m 25d Gender: Male Location: sydney Posted 20/12/10 01:49 AM Author Posted 20/12/10 01:49 AM eh I hope john.car wont rev over 3000rpm or 5 psi boost and then splutters when driving but when parked revs to 5000 no probsisnt a problem with cat just going to check pump now
John_K Legacy Donating Member 438 Member For: 17y 10m 1d Gender: Male Location: Sydney Posted 20/12/10 03:21 AM Posted 20/12/10 03:21 AM Still sounds an exhaust blockage or a vacuum/boost leak somewhere. Check ALL cooler pipes including under the car.
nathen ride the lightning Legacy Donating Member 338 Member For: 19y 11m 25d Gender: Male Location: sydney Posted 20/12/10 04:32 AM Author Posted 20/12/10 04:32 AM replaced all coil packs.cat taken off all clear.checked hoses.error came back p2105 tps switch.bought another throttle body and switch.I will replace that and look at fuel pump.if its not that then it looks like im off to c@v.only thing is im a bit pissed that I may need to buy a new xcal3..somethink I realy dont want to do since sct screwed us out of xcal1
John_K Legacy Donating Member 438 Member For: 17y 10m 1d Gender: Male Location: Sydney Posted 20/12/10 05:25 AM Posted 20/12/10 05:25 AM Key off. Hold accelerator to the floor the try starting the car. It shouldn't start.This "may" help to reset the TPS.
nathen ride the lightning Legacy Donating Member 338 Member For: 19y 11m 25d Gender: Male Location: sydney Posted 20/12/10 05:44 AM Author Posted 20/12/10 05:44 AM tryed that john.so far today put all new coils on .checked plugs again.checked cat no problem ,replaced fuel filter.reset tps.replaced tps.car could be in limp mode?going to check fuel pump.could also be actuater
boost69 Legacy Donating Member 737 Member For: 21y 4m 17d Posted 20/12/10 05:44 AM Posted 20/12/10 05:44 AM I still reckon cat too...revving in neutral doesn't create the same exhaust flow as in gear driving would...from my experience with blocked cats you wont make boost and as it deteriorates further when you try and accelerate the car chokes and will even stall on you (zero power can only be driven at a snails pace)...otherwise its a vacumn leak but a vacum leak that significant will also usually affect the idle speed... you would usually get your revs go up and down at idle...
nathen ride the lightning Legacy Donating Member 338 Member For: 19y 11m 25d Gender: Male Location: sydney Posted 20/12/10 05:53 AM Author Posted 20/12/10 05:53 AM cat removed today .no problems.before taking the cat off we removed inlet pipe so no boost car drove like a normal 6 drove perfect.connected pipes back up spluttered and wouldnt boost over 5 psi.removed cat and all good.replaced all above and with tps feels a little better.so im thinking either wastegate problem or fuel pick up may be blocked.I have a walbro intank pump.just going to check that the cradle is all the way down.feels like car is running out of fuel hesitates and then splutters.how do I reset computer? I will try tps reset again
John_K Legacy Donating Member 438 Member For: 17y 10m 1d Gender: Male Location: Sydney Posted 20/12/10 05:57 AM Posted 20/12/10 05:57 AM Reset ECU?
nathen ride the lightning Legacy Donating Member 338 Member For: 19y 11m 25d Gender: Male Location: sydney Posted 20/12/10 06:23 AM Author Posted 20/12/10 06:23 AM best way to do it?
