  • Member For: 15y 9m 2d
Hey guys haven't posted here in a while!
Basically I'm finally getting some work done to my ba xr6t.
I would like for the time being around 250k kw.
I am getting a xflash3 with custom tune, injectors and fuel pump.
But here is the question;
I have been quoted:
42lb/hr Bosch 968 Injector - Multi-orifice | $600 set 6
HMS OEM High Performance Fuel Pump replacement complete assembly $515
Are these a good price/good product? Or is there a better alternative?
Would it also be worth getting them to throw on a higher flowing cat?
What other mods to you guys recommend to achieve the measly 250kw that I'm looking for?
https://www.fordxr6turbo.com/forum/topic/72187-need-some-advice-please/
  • Member For: 17y 1m 28d
250, the price for injectors seems about right for 968s, which it your not Going for more later you should stick with as they have better idle and slightly bettercontrol than bigger injectors.
The fuel Pump price sounds about right for the complete unit too.
A hi flo cat will help it make the power with less boost, so definitely worth it.
Are you sure 250 is all you want though.
Ideally I would like 300. But from what I have been told valve float will happen around there.
I can only really afford to be without a car for a day, but in april I'm away all month so Ill book it back in.
Here is the list I have thought of to get my 300. Please feel free to add or adjust it.
(Sedan) HMS OEM High Performance Fuel Pump replacement complete assembly
XFlash3 with 1 performance Tune
Heavy duty Valve Springs
Hopefully would find a turbo back exhaust on here for cheap enough
Process West Stage 1 Intercooler kit
Am I on the right track? Should I just wait a few more months and get it done in one hit?
  • Member For: 16y 18d
If I was you id look at valve springs and transmission.....orrrrrr buy an 07 BF MK II turbo...better build and typhoon bottom end :D
Edited by osonvs
  • Member For: 18y 1m 6d
umm $600 for 42lb injectors? you can get 60lbs for $350 brand new
and you can also get a walbro fuel pump for less then $200 brand new
sounds like a rip off to me man.
  • 570Nm @1800rpm
  • Member For: 21y 7m 26d
At those prices you are getting shafted!! :turboboink:
Check these links for fuel pump and injectors. Call them direct if you have never bough from ebay before.
Fuel pump assembly for $253
http://cgi.ebay.com.au/SENDER-WALBRO-GSS340-FUEL-PUMP-FORD-XR6-TURBO-BA-BF-/370466155699?pt=AU_Car_Parts_Accessories&hash=item564180ecb3#ht_3485wt_905
60lb Deka injectors for $330
http://cgi.ebay.com.au/SIEMENS-650CC-DEKA-60-FUEL-INJECTORS-XR6-TURBO-LS1-XR8-/370466155696?pt=AU_Car_Parts_Accessories&hash=item564180ecb0#ht_5299wt_905
To help your valve springs grab a 100CPI Rapid cat, this will relieve some of the back pressure (make sure you get a 100cpi cat). Also for the sake of it cluck on something like an F6 or Monza cooler, they are both average but will be better then the stock XR6 cooler.
Guest Slash
  • Guests
^^^THIS!
  • Banned
  • Member For: 15y 10m 1d
lawl henz...where do you go shopping for parts?! yeesh.... 600 for 42s is full lawl.
what DJ said. you will only get 250-270rwkw with out valve springs done.
just get deka 60 injectors and tune and you should get 250rwkw no worries. Cat and fuel pump aint needed but nice to have
