  • Member For: 14y 6m 13d
Hi all
Let's say you get -injectors
-high flow cat
-intercooler
-tune
Say it makes 320 rwkw or so. But then boost decreasing from 15 psi peak to 11 psi towards the 5000-6000 rpm.
Is there a way to reduce that effect? Air intake or waste gate actuator or something else?
https://www.fordxr6turbo.com/forum/topic/71346-why-boost-is-decreasing/
  • Member For: 15y 3m
Has it been tuned?
Normally when you have a bigger cat, you get boost jumps.. and it dripples down..
get it tuned champ!
  • Member For: 18y 8m 14d
Yea the STD actuator has a 3psi spring if I remember correctly, and won't hold 15psi.. Get an actuator with the spring suited to what boost u want to run, so for a 15psi tune you should get a 12 psi actuator, you could get a 15psi one but you won't be able to run less than 15psi.. Unless your happy with that..
