  • Member For: 16y 4m 11d
Posted
Can anybody recommend what's the best road track tyres to use on track days,I am drivIng a F6 and have just shredded my tyres after four outings, I feel the f6 needs bigger boots on it to keep the traction and power on the bitumen, if any one has had similar experience let me know .will 265's fit on the rear of the 19 inch rims?
  • A much better forum
  • Legacy Donating Member
  • Member For: 18y 2m
Posted
Is it only rears??? Or front and back???
If you want decent traction, you need soft rubber... If you have soft rubber, you'll never get any life out of them!!!
Maybe buy some track rims? 18x9's... And fit 265 front and rear... Kuhmo ku36???
Posted
Thanks for the advice ,I ve got a set of BA XR8 rims which are 18's which I'll try to see if they will fit the fg,I've got the 6 pot brembos so theres not much room. :buttrock:
  • Member For: 16y 10m 1d
Posted
what riphsv said,,
I got an omg :D!!!!!1 soooo good my car feels twice as fast wonder what it would feel like on front tyres too!
but you cant get them in any thing over 18's
  • Member For: 23y 1m 18d
Posted
Pretty sure BA XR wheels will not fit over the Brembos you have. There are two options you can go for either a set of semi's you can drive around on and use at the track or have another set of wheels for track work only. If you go for the first option then KU36's are great but come in only number of 19 inch sizes that don't suit the Falcon. If you 18's then all good. I've heard they are ok at the track but not the best. If you go the second option then a seperate set of wheels preferrably 18 inch will allow for many different options for tyres. I'd probably go for a set of Toyo R888's.
Benny
Posted
Tried the Ba rims on today and they did fit with plenty of clearence,so I think the second option is going to be the way to go.Toyo tyres keep getting mentioned so I'll look into them.It's a pitty theres not much in 19's do you know of any which would suit or is it going to be to pricey.
  • Member For: 21y 8m 7d
Posted
I use the bridgestone adrenalins awesome tyres, quiet on the road and enough grip for mild track use
