  • Member For: 22y 2m 8d
Posted
Hey guys,
For the last 2 months I have noticed at the same spot on the road on the way home (about 15mins at a round about) if I put the foot down it will only get to 3PSI and not 10PSI. If I drive another 1khm down the road it will get to 10PSI. WHY????
  • Legacy Donating Member
  • Member For: 18y 10m 16d
Posted (edited)
That sounds freaky. I vote for some sort of outer space no oxygen wormhole zone.
edit - it's not hilly is it?
Edited by -SteveR-
Posted
The only thing I can think of is that the lower PSI area is downhill? Flooring it and seeing 7PSI difference is confusing though. Are the boost levels the same travelling in the opposite direction? That'd REALLY be screwy.
  • Waiting for the 1st N/A 12!
  • Member For: 18y 7m 29d
Posted
Is your traction control cutting in perhaps?
Posted
Nope, tried that. Going home it works fine. I'm thinking maybe cause I'm sitting in traffic for a while (5mins at traffic lights). Could it be the MAP VS Intake Air Temp table and ECT multiplier table?
Posted
Sounds a bit twilight zone mate! Weird! have you tried different approach speeds to the same area?
Posted
Maybe try a diffrent way home! Seems you might be driving over secret underground miltary jamming sub station that only effect XR6 turbos!
  • Member For: 18y 11m 1d
Posted
Try the trip at night so you can get a decent average road speed. Take note if it happens in the same spot going in both directions. This info may help solve the mystery.
