Marzy New Member 2 Member For: 13y 8m 16d Posted 29/09/14 04:23 PM Posted 29/09/14 04:23 PM Excellent postMy g6e won't function in sport or sequential mode. Fuses are are all happy. Before I explore under the shifter do you think I'll find a potential loose terminal (culprit) under there or are the simple wire terminals generally rock solid ??Go exploring or look elsewhere such as a ZF module fault ?CheersWhat did it end up being ? Mine wasn't working so I let it auto change gears then manually changed down and then it worked going up manually.
Wilko16 Legacy Donating Member 1,672 Member For: 18y 10m 20d Gender: Male Location: Melbourne Posted 06/10/14 06:50 AM Posted 06/10/14 06:50 AM Great post, helped me out a lot!And in regards to the gear shifter, those little wires that you have to unplug underneath the auto surround actually control the transmission... There is a little magnet on a stick on the right side of the shifter and this is what tells your tranny to shift into performance or manual modesSo it is important not to damage these wires or the little magnet on a stick
